Old 01-13-2023, 10:58 AM   #20 (permalink)
oil pan 4
I'm going good to switch over to e10 gas and I should be getting a #62 jet in the mail later today.
I'll run it off e10 dishwater for a while and slide in the #62 jet when it shows up today. If the engine sputters on e10 with a #62 it should be perfect on true gasoline.
If it seems to run good with e10 on a #62 then I also have a #58 and a #60 on the way.
A #62 should do the trick.
I want to be able to use the factory warm air intake and not run rich.
