Old 01-24-2023, 12:55 AM   #36 (permalink)
Christian
EcoModding Noob
Christian's Avatar
Mazda 3 - '16 Mazda 3 Hatchback GS
In my country, the driver licensing test is done with manual transmission, unless the car is adapted for disabled drivers (actually some cars adapted for disabled drivers here are still fitted with manual transmission). Odd enough, the manual transmission is no longer available for some cars locally, even though it's often still found on export-bound versions...
Are you in Europe? Here in Canada there is no distinction between a manual or automatic driver's license.
I did my driver's test at 16-17 in an automatic car, and about 2 years later I bought a car with a manual transmission. As you can expect, there were some hiccups along the way, but I always thought it was weird that I didn't need to get tested in a manual transmission car. Can't say I got into any crazy situations though, mainly just awkwardly stalling when the light went green and pissing off other motorists (unintentionally).
