Old 04-13-2023, 03:21 AM   #9 (permalink)
Christian
EcoModding Noob
Christian's Avatar
Mazda 3 - '16 Mazda 3 Hatchback GS
I noticed on your website you claim that your product
will help your engine to reduce smog emission by 50 to 70%.
do you have any independent certified/published test results that prove this? Other than a low-res "before" and "after" photo on your website?
It honestly seems that your goal is to generate sales by using big words and science-y language... Shown below is another snippet from your website's "patent" tab. Am I wrong?
1- Collecting air by the front grille through a stainless hosepipe (also used to refill the evaporator if necessary).
2- The Evaporator is increasing hygroscopicity value to produce the best active air through bio materials like ceramic, to modify water structure creating a tensio-activity,
3- The next step is to go through the reactor, with a ferro-magnetic charge, guided by an amorphous material. His mission is to « scratch » the air and energize the hygrometrically saturated air.
4- The Engine suction will create a vacuum turning on and off this device.
You also claim on your website that your product is both
transferable from one vehicle to another in minutes.
and
Estimate installation time 1 to 2 Hours
So why would we need to be located on the East Coast? Can't we install it ourselves?
One final note, you have a big "Edison Awards 2023 Nominee" badge on the top right corner of your website, yet I find nothing on their website listing your product as a Nominee. https://edisonawards.com/nominee-gallery
Last edited by Christian; 04-13-2023 at 03:37 AM.. Reason: formatting + missed point
