Old 06-02-2023, 01:59 PM   #5 (permalink)
oil pan 4
The problem with batteries is they're heavy. A 2019+ leaf battery has a volume something to the tune of 60 gallons or more but weights over 900lb and only holds the energy you would get out of maybe 5 gallons of diesel if burned for electricity in a piston engine. Then if it's burned in a combined cycle gas turbine steam engine you get double the power out of that much fuel.
That 900lb battery will only let you go 200 miles or so, a diesel fuel tank would weigh half as much and power the car for more like 3,000 miles.
