Old 10-23-2008, 11:02 PM   #20 (permalink)
RH77
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
I finally got everything moved to the server drive, on to the new Toshiba drive, and kicked the old one out the door.
So then, I found a secondary drive in the server that was the original backup drive until it ran short on space. It had some tunes on it that I lost a while ago. Sweet!
Then, click, click, and that variable drive-speed sound. ****! Then it would intermittently show up in XP, then finally as a having 0.00 GB. I did the Master, Slave, CS, Primary, Secondary combos and nada.
The brand? Yup.
When it absolutely positively has to fail tomorrow, choose WD!
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
