Old 01-05-2024, 05:05 PM   #7 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Originally Posted by Otto View Post
So, how thick should the Coroplast be for stiffness in an undertray?
4mm? 6mm? 8mm? 100mm? What?
FWIW I have been using a free used political sign for my belly pan for over a decade. It measures 3/16" or 5mm. it is more reinforced than the photos in my album show but other than that is is holding up fine. My car is a diesel so the exhaust is fairly cool. I covered the whole bottom of the car from just behind the catalytic converter.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
