01-04-2024, 09:29 PM
Best Coroplast thickness for a small car undertray?
What's the consensus view?
The Following User Says Thank You to Otto For This Useful Post:
01-05-2024, 12:56 AM
Useful for mockups and testing, not the long haul. If you do use it here's a[n untested] suggestion for shaping and edging it with wire reinforcement.
Shallow notch for taped edge, deeper to wrap the edge, Wires through the corrugations to hold curved shapes.
.tragectory: Line goes down and to the right.
01-05-2024, 09:20 AM
And: stiffer along corrugations, bendier with corrugations 90 degrees to bending force. freebeards post shows the need for reinforcing in the bendier mode
01-05-2024, 10:06 AM
So, how thick should the Coroplast be for stiffness in an undertray?
4mm? 6mm? 8mm? 100mm? What?
01-05-2024, 11:37 AM
I think the deciding factor here is what DF is likely to be created. In racing it is the goal, and not a full negative result (pun intended) here I suspect combined with how the panel is supported and what the mounting spans/frequency is, and what effect any ambient heat (exhaust, etc) will have on the panel to weaken it.
Some flexibility might be a plus in helping have a favorable outcome with the occasional road debris.
My application I'm seeking DF first then drag reduction, I'm leaning towards 8mm CF/kelvar honeycomb custom fitted/shaped w/HT epoxy.
01-05-2024, 02:35 PM
Whatever is free, it's only for mockups.
Maybe for complex shapes like a diffusser. For flats or simple curves, Polymetal/Alumapanel composite.
01-05-2024, 04:05 PM
Aero Wannabe
FWIW I have been using a free used political sign for my belly pan for over a decade. It measures 3/16" or 5mm. it is more reinforced than the photos in my album show but other than that is is holding up fine. My car is a diesel so the exhaust is fairly cool. I covered the whole bottom of the car from just behind the catalytic converter.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
01-05-2024, 04:35 PM
200mm. itll keep all air from going under the car
The Following User Says Thank You to Phase For This Useful Post:
01-06-2024, 11:06 AM
#9 (permalink)
' consensus '
Years ago, I thought it was generally agreed that, the 10mm Coroplast, from The Home Depot had turned out to be more than adequate for belly pans.
It's a thermoplastic, and will 'yield' at some temperature threshold, but exhaust components can be insulated, or heat-shields fabricated to mitigate heat effects.
Sag testing will reveal necessary center-to-center support spacing.
And hat-section stiffeners can be attached wherever deemed beneficial.
Consider 'sections' of pan, which can readily be removed for inspection.
