Old 01-20-2024, 11:13 AM   #4 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
Late to the party...
Cool experience & nice review, Ecky!
My understanding of the powertrain is that, it's powered by a high compression 14:1 CR 1.5L, which is attached to a motor generator. The wheels are driven directly by a 107hp electric motor, and the gasoline engine spins up and down depending on the electricity needs. It isn't like a Prius or Volt, where engine torque can be sent to the wheels through a planetary gearbox - there's no physical connection. The engine is only attached to a generator, though with a caveat. There's a clutch that connects the engine with a single speed reduction gear once the car is going fast enough - around 100kph or 60mph, I believe. There's a small lithium battery hidden where the spare tire would go.
Sounds like the Nissan Note series hybrid. The Note's wheels did NOT have any physical connection to the engine though (a 1.2L triple, if memory serves).
Thread: Nissan Note series hybrid: Leaf drivetrain + small battery + 1.2L generator
