Old 01-10-2025, 08:09 PM   #828 (permalink)
redpoint5
90 day: 29.78 mpg (US)
All data and predictions are fake <==> It's all a Simulation
There must be a step #2?
He says that out-of-state builders will be working under California rules. I see a big opportunity for Geoship.
They're in Nevada County, CA, and they could metastasize their cast geopolymer manufacturing process and introduce a 'So-Cal' model with a big water reservoir at the summit, with a Rainbird (LF2400 --38-50ft radius) and foaming agent. Fireproof house, protected landscaping.
The curved TV fad just needed domed houses to catch on.
In my mind, the insulation and structural support should come from the same material, with other materials only used as a facade (better if the insulation and structural material is also a finished surface for a threefer).
Still waiting for LCD windows that can gradually transition from nearly 100% transparency to nearly 100% reflective. Window treatments are an ancient solution that needs to be retired.
