A squashed W. Heh heh.
That, I would like to see. Wait..... Yes we can.
Yes, you have to cut it upwards at the ends as it goes around the corners. I actually put mine on oversize then reached in and marked it with a sharpie, took it off and cut it. It ends up mostly parallel so the bottom edge curves up a bit too. I'm eventually going to trim the upper edge with an aluminum strip.
Nice dam back at you! As big as my dam is I think you beat me in the frontal area to air dam ratio amazing as that may seem.
p.s. I just pulled another ford part for my modding madness: A map sensor to mod the cruise control for vacuum cruise.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
