Old 11-26-2008, 06:23 PM   #41 (permalink)
orange4boy
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
I didn't take any photos of the rear install but the Aluminum flat bar is 1/8" x 1 + 1/2. It curves in at the ends and four screws hold it to the plastic trim. There are two other brackets at 10:00 and 2:00 also attached to the plastic trim. I wanted to avoid drilling into metal for obvious reasons but you may be able to make a long L braket that attaches further into your wheel wells where you might have plastic fender wells to screw into.
You can drill into metal if you paint a good qwuality primer into the hole then follow up with undercoating gobbed into the holes and on the screws. Stainless screws are best of course.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
