Originally Posted by PA32R
The results from that Mythbusters episode are summarized here. I use this technique when it's available and likely to help. I ran some numbers on safety of the technique here. Finally, I estimated when it's likely to save fuel, i.e., when the fuel savings gained are not outweighed by having to go faster to keep up with the truck here.
Read your blog post you referenced about reaction time. My concern is not with the truck braking so much as the truck seeing something in the road (like a tire tread.) He's high enough to clear it, but you may not be, and might sustain some damage.
If I did a lot of cross-country driving (where it would make sense to make the effort to draft a lot), I might get a CB and ask ahead of time if I can draft. Some truckers are more amenable to this than others, but all appreciate being asked first.
That said, I do draft at 75-150 feet (depending on speed) during my commute, for 2-5 minutes at a time.
