Thread: MPGuino problem
Old 11-28-2008, 10:34 PM   #12 (permalink)
orange4boy
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
I'm starting to think it's a voltage problem. It froze and / or reset a few times today, usually when I had a large load on the batteries. I am running without alternator and voltage drops under 12 sometimes. I will have to hook it up to a separate battery and in an enclosure to eliminate those possibilities.
Is there a minimum voltage where it resets or data is corrupted?
If that does not do the trick next possible cause would be signal issues, I guess, reading from other posts.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
