Old 12-02-2008, 11:50 PM   #54 (permalink)
orange4boy
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
Lately been playing around with my new MPGuino. Testing P&G and calibrating. Been having some trouble with screen freeze which I have yet to figure out. I will have to try powering it from an separate battery to see if it's a voltage issue.
Found a Ford MAP sensor which I plan to hook up to my cruise control to see if I can get vacuum regulated cruise. This is mostly for fun because I'm getting pretty good numbers from P&G.
I have the sensor, a 5V regulator and I know my VSS is about 8000 so they should play well together. Now I have to find the cruise control module somewhere under the shuttle dash. I have to run the wires for my vac gauge and mpguino anyway so...
Also been playing with HUD-MPGuino.
ID:	2302   Click image for larger version
ID:	2303   Click image for larger version
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
