Old 02-02-2008, 10:42 AM   #3 (permalink)
RH77
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
Addl. Info
Originally Posted by Lazarus View Post
I love the looks of this car and have to stop and stare every time I see one. Always wondered how it would do on FE in the hands of a hypermiler. What are the EPA numbers for the hard top and do you know the CDa. Great report thanks.
It was always parked in the "VIP" or "Ridiculously Expensive Rental" spot, but due to the lack of availability (and phasing the '07's out), they parked it in the "average guy" section.
I have to preface the mileage that minimal hypermiling took place: speed limits on the highway and soft acceleration at times, but that should have made up with handling tests and strong acceleration at times.
The Coupe and Convertible have the same EPA ratings, but the transmission choice determines your mileage:
6-Speed Manual:
17/25
Automatic:
21/28
I would bank that 30 could be attainable, but EOC would have to be minimal. Steering is quite difficult with the engine off -- likely due to the large contact patch of those 18" wheels/tires (despite the RWD config).
The auto is geared well and uses its technology to keep the RPM down in City applications: a paradox of mileages compared to the usual expectations of stick vs. auto. Technique, mods, and a good mix of additional highway miles (with fewer aggressive accelerations) would lend itself to much better mileage.
Further: the manual and automatic has the same final drive and final gear ratios; however, the manual has shorter gearing up to final, which may account for the difference.
Drag Coefficient is a stout 0.37.
I hear that you got to drive a Bimmer lately
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
