Old 01-01-2009, 10:21 PM   #5 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
My 2009 modding resolution: finish my 2008 list!
You do remember what you resolved to do in 2008, don't you?
See the thread: http://ecomodder.com/forum/showthrea...list-1199.html
Let's see... How did I do?
2008 Metro goals:
- properly affix rear skirts (brackets)
- make permanent partial kammback
- experiment with front air dam
- develop front wheel skirts
- test airtabs
Metro wish list:
- lowering
ForkenSwift goals:
- dissassemble, clean & repaint everything (motor, racks, engine compartment)
- install battery pack LED monitor
- add DC/DC converter (sort of - it's duct taped in place)
ForkenSwift wish list:
- add 2 more batts on a controller bypass circuit for 60v turbo mode
OK, not as bad as I thought!
So then for 2009 I'd like to tackle:
2009 Metro goals:
- get my cruise control working/replaced (again) so I can get back to A-B-A tests
- finish front wheel skirts
- do a ride height lowering A-B-A test
- develop a removable boat-tail prototype, and A-B-A it
- reinstall the full belly pan after lowering the car (or not)
- probably some other smaller things I forget at the moment...
2009 ForkenSwift goals:
properly install the instrumentation - the LED pack monitor & ammeter are currently duct taped to the dashboard
- properly install the DC DC converter
- properly install the charger & plug
- finally clean up the interior - it's the dirtiest I've ever seen!
- investigate that "turbo" boost circuit
