Originally Posted by Christ
FastPlastic - You lucky summuna.... here is your throttle body gasket:
![](http://info.rockauto.com/getimage/getimage.php?imagekey=1191312&imageurl=http%3A//info.rockauto.com/Airtex/1G1212.jpg)
Yup. Should be about to knock that out in 15-20min. Probably spend more time looking for longer bolts if I need them.
Coyote X - Did you end up replacing the mounting bolts?
