Old 03-06-2009, 01:14 AM   #11 (permalink)
RH77
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
More or less the stock filter element with custom, temperature dependent, air sourcing is my choice. I tried K&N, but it yielded no advantage -- in fact the maintenance quite costly and the darn thing disintegrated (I know, there's a warranty, but I don't want another).
I have a straight pipe entering the airbox to draw warm air from the exhaust manifold. The disadvantage is a growl under high throttle input. Otherwise, the filtration rate is moot so the OEM paper replacement is just fine.
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
