Go Back   EcoModder Forum > EcoModding > EcoModding Central > Engine options for a CRX
View Poll Results: What engine for a 1990 CRX?
This poll will close on 07-17-2011 at 08:39 PM
Re-build the stock engine yourself. 1 11.11%
Pay someone to rebuild the stock engine. 1 11.11%
Swap an HF drivetrain in. 0 0%
Later D16Z6 engine. 1 11.11%
Swap in the lean-burn HX engine. 6 66.67%
B-16 swap; 160 HP and 111 lb-ft of torque. 0 0%
B18A (Integra LS) swap; 130-140 HP and good torque; taller gearing. 0 0%
Integra GSR (B18C) motor, bec ause 180+ HP and short gearing is good. 0 0%
Voters: 9.
