Originally Posted by Jakins
So you switched it up so you can have them more sunk in the rear? Our for the simplicity of making them smooth?
Four reasons.
1. Bigger offset so I can cover rear wheels more easily + smaller frontal area.
2. Easy to make them smooth
3. Since roads in Eastern Europe are not the best quality I want to have higher tire with the same outer diameter. It will act much better than low profile one.
4. 15" tires are cheaper than 16"
