05-03-2013, 12:41 PM
ACM board much better than coroplast
For those in range Ive found ACM for $40 a sheet in ATL. GA.
it is sandwiched .07 aluminum sheets with poly center, not much more weight than coroplast and much more durable and attractive.
Atlanta Specials
05-03-2013, 04:54 PM
"prices valid through march 31, 2013!"
05-03-2013, 05:56 PM
ok........how bout you spell out ACM.
Since after a quick search (link was to a home page NOT the exact product) I have no idea what I'm looking for.
also, how about some pics?
4ft x 8ft coroplast is $19
05-03-2013, 06:14 PM
Eleven dollars each in lots of ten, delivered to Home Depot.
48 in. x 96 in. White Cap Corrugated Plastic Cardboard (10-Pack)-WC4896-10 at The Home Depot
Thanks to KamperBob http://ecomodder.com/forum/showthrea...tml#post367796
In http://ecomodder.com/forum/showthrea...ast-12100.html, Cd said "If you want cheaper Coroplast, try your local recycling center. It's FREE"
05-03-2013, 06:19 PM
so I spend $110.00 and get 9 extra sheets why?????????
05-03-2013, 08:29 PM
I do not know, but I am glad that I reposted, just for the laugh.
Honestly, I have been wondering who actually uses ten sheets, three hundred and twenty square feet, ever--besides politicians.
I guess that if your plans require seven sheets, which you could get for nineteen dollars each, you might go for it.
05-03-2013, 08:50 PM
lol
05-04-2013, 03:06 PM
I believe ACM is Aluminium Composite Material, but I do not know wnything about it - personally.
05-04-2013, 04:21 PM
#9 (permalink)
PolyMetal
Available through my local distributor, Multicraft Plastics, for three different prices depending on whether you present yourself as a wholesaler, business or individual.
I've worked with samples. It's available in 4x8, 4x10, 5x8, 5x10 [project sized] pieces.
Also, see:
Alumacorr vs. Poly-metal
05-04-2013, 04:52 PM
#10 (permalink)
PolyMetal
Also, see:
So, which would you use, and what would you do with it?
