Old 01-12-2025, 11:19 PM   #1 (permalink)
lead foot
Adding EGR to Honda with Kpro
I am renewing my interest in my K swapped turbo Insight which was for commuting into the big city. Since I retired I have decided to Door Dash in my small town. I want to pull the turbo motor out and run a stock K24a4 Accord motor and geek out on fuel consumption with a purpose. K24s came with and without EGR valves and anyone that adds Kpro to the engine will run without.
First question for the group is should I add EGR at all? What kind of gains in MPG can I expect with a properly functioning EGR?
Second question is for the Hondata Kpro types.... With all the functionality of kpro would there be a way to properly control it, maybe the NO2 output in some way? I have also thought about wiring in a manual switch just to play with it.
2001 Insight 11.5:1 K20a3 turbo / 04 Element
Old 01-13-2025, 04:32 AM   #2 (permalink)
90 day: 39.72 mpg (US)
90 day: 59.95 mpg (US)
You're better off running KTuner, which (I believe) has native EGR control, since it's based on the Accord ECU.
There are some threads on Insight Central where, I think it may be Julian Edgar? experimented with various degrees of EGR, and quantified the gains.
Edit: KPro does well with on/off controls but doesn't easily do tables for peripherals. You would need an external controller (Arduino would do it), or pick a good EGR duty cycle and just turn it on to that when outside WOT conditions.
Old 01-27-2025, 08:14 AM   #3 (permalink)
Replying for the update.
