Old 01-23-2010, 05:19 PM   #51 (permalink)
old red taco - '02 toyota tacoma regular cab
90 day: 29.49 mpg (US)
[IMG][/IMG]
The Following 2 Users Say Thank You to ccrider For This Useful Post:
BamZipPow (04-14-2015), mikeyjd (03-01-2014)
Old 01-23-2010, 05:21 PM   #52 (permalink)
one more of the frame
The Following 3 Users Say Thank You to ccrider For This Useful Post:
BamZipPow (04-14-2015), mikeyjd (03-01-2014), mully (01-24-2010)
Old 01-23-2010, 05:36 PM   #53 (permalink)
Aero Deshi
ChazInMT's Avatar
MagMetalCivic - '04 Honda Civic Sedan EX
Last 3: 34.25 mpg (US)
Looks Great CC. I'm going to be in Peekskill NY in a month, maybe we get together for a Gyro at Tony's Greek in Fishkill and compare notes, and freak people out if they see 2 aerocaps in the same place at the same time!
Old 01-23-2010, 06:11 PM   #54 (permalink)
Originally Posted by mjboks View Post
Just as I expected, not the best aero design.
It looks like it would start separation about 1/2 way back over the cap. It's really too bad this style though hasn't migrated to n.america.
OK I don't like this whole "template" business to begin with, but this example made me realize something. You can scale the template, and it will fit that curve. Then you wouldn't be saying that separation starts 1/2 way back. The application of these templates is completely arbitrary.
Old 01-23-2010, 06:17 PM   #55 (permalink)
you cant scale down the template if you line up the roof of the vehicle with the top of the template and line up the bottom with the road. all you can do is slide it front to back so it lines up better
Old 01-23-2010, 10:35 PM   #56 (permalink)
bondo's Avatar
Nice work ccrider.
I just did a pencil outline of your lid in side view. It is real close to the profile of the one on my Ford, just a little taller in the back. I think it is going to work good. Here is a photo of a yarn test on mine below. You might get some yarn and stick it on your cap. Have somebody drive your truck for you and you follow it in a chase car and study the yarn to see if and where the air may possibly detach.
When I built mine I had zero information to go by. I know how difficult it is also to fabricate something this big by yourself. I have a great deal of respect for all you guys who go for it and build your own aerocaps. Also MetroMPG has my greastest respect for the fine job he did on his tail cone. 15% increase in fuel efficiency is outstanding!
By far the most rewarding thing is getting out on the road with your new aerodynamic article you have build get a resulting reduction in your fuel usage.
Bondo
Old 01-24-2010, 12:08 AM   #57 (permalink)
What is the relevance of the height of the vehicle? What if the truck had a 4" lift and bigger tires adding another 2"? Does the optimal slope and curvature change?
No. It still has to be shallow enough for attached flow at a given speed and steep enough to reduce cross section significantly. The template means nothing.
Old 01-24-2010, 12:44 PM   #58 (permalink)
Quest for a 400 mile tank
mjboks's Avatar
Adventure Truck - '07 Toyota Tacoma Double cab V6 TRD 4wd offroad
90 day: 19.26 mpg (US)
Commuter Bicycle - '94 Slingshot mountain bike
Yup, the template is adjusted from the ground. Do a "template" search on this site and you'll find a lot of info about aerodynamics. There have been a lot of research done on this.
The Following User Says Thank You to mjboks For This Useful Post:
ccrider (01-24-2010)
Old 01-24-2010, 03:07 PM   #59 (permalink)
Aero Deshi
ChazInMT's Avatar
I question this too and have a good post on the "Tiger woods meets Ciderella" thread. It seems as if flow is going to separate it will do so when it gets pulled to that 115° point beyond the stagnation point of the shape in question. Check out the post and weigh in whether you think Green or Red.
Old 01-24-2010, 08:14 PM   #60 (permalink)
chazinmt send me a email when you are in the new york area.
i painted the cap tonight that cost me $15 so the totall cost is up to about $45. tomorrow i will take it on a 200 mile trip hopefully i will see some results.
Report: Improving the Aero Characteristics of a Dodge Ram Pickup Truck MetroMPG Aerodynamics 36 08-05-2013 11:25 PM
2008 Dodge Dakota AeroCap electricman Aerodynamics 52 10-08-2011 10:47 AM
A Pickup Truck Project Big Dave EcoModding Central 47 09-12-2011 11:42 AM
Article: pickup mileage - manufacturers are ecomodding their trucks for better MPG MetroMPG EcoModding Central 14 10-07-2009 11:49 PM
Pickup tailgate up or down skyl4rk Aerodynamics 26 09-02-2008 04:49 PM
