Old 01-21-2011, 10:11 PM   #1 (permalink)
bondo's Avatar
Aerocap Thesis from 2009
Found another Engineering students Thesis on aerocaps I thought you guys might like to review.
There are some nice CFD graphics and a curved Aerocap was found to reduce the Cd the most. The fuel efficiency gain comes out to about 1 mpg in the calculations derived from the students CFD simulations.
I have experienced a higher percentage of fuel efficiency gain at around 3 mpg or 15% at sustained freeway speeds. Round.boater has seen a 15% increase also in the fuel efficiency of his truck since running an Aerolid, which he has recorded in his fuel log here on ecomodder.
round.boaters fuel log
http://ecomodder.com/forum/em-fuel-l...vehicleid=2565
In the last paragraph of the thesis, on future work, the student states a need to test an aerocap on a truck in the real world along with other aerodynamic devices.
Link
http://csus-dspace.calstate.edu/xmlu...pdf?sequence=1
Bondo
The Following 5 Users Say Thank You to bondo For This Useful Post:
aerohead (01-22-2011), BamZipPow (01-21-2011), slowmover (01-22-2011), t vago (01-21-2011), The_Original_Modifier (12-29-2011)
Old 01-21-2011, 10:39 PM   #2 (permalink)
...beats walking...
...nice to read about the 3" and 6" height front air dams too!
Old 01-21-2011, 10:42 PM   #3 (permalink)
bondo's Avatar
Yes it is.
I also like that different angles of the aerocaps were simulated. 12 degrees looks to be the best.
Old 01-21-2011, 10:43 PM   #4 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Dang me... My cap was indeed too aggressive. I had a 20 degree downangle. The coefficient of lift for 18.77 degrees increased by 63% over the baseline, in that paper. No wonder my aerocap flew!
Thanks!
Old 01-21-2011, 11:00 PM   #5 (permalink)
bondo's Avatar
Yeah t vago, lift is good for aircraft, bad for aerocaps.
The wind tunnel tests I did on my Aerolid in the A2 wind tunnel in North Carolina showed a significant increase in lift too. My lid is around a 12 degree slope. The students thesis shows a reduction in lift, at 12 degrees, which does contradict the data derived from test on my lid in the A2 wind trunnel.
Old 01-22-2011, 06:18 AM   #6 (permalink)
Would adding tailplates lower the cd on the 3D aerocap?
Old 01-22-2011, 08:54 AM   #7 (permalink)
MPGuino Supporter
t vago's Avatar
I can definitely tell you with 100% certainty, that the answer to your question is a firm and definite maybe.
Old 01-22-2011, 11:20 AM   #8 (permalink)
n00b.... sortof..
d0sitmatr's Avatar
silver fire - '03 Mazda Protege5
90 day: 32.52 mpg (US)
excellent read !
although I did notice here was not much variation between a standard aerocap @ 10 vs @ 12. however, the angled cap did provide a much greater difference over both straight 10/12.
going by that study, the best gains would come from a front air dam @ 6" coupled with the curved (angled) aerocap.
which also makes me feel much better since that was the direction I was going to take with my Ranger prior to trading it
~Mike
Old 01-22-2011, 04:07 PM   #9 (permalink)
angles
I sure wish we could get away from 'angles'.Angles don't occur in high-performance structures,only compound curvature.
One can only discuss a particular angle,tangent to the body curvature,at any particular point,not some general area of the structure.
The folks did a lot of work.And the values are appropriate for their model,nothing else.They've essentially re-discovered Paul Jaray's work of 1922.
One would be warned if they believed any fast and hard rules would apply to these results when extrapolated out onto the general pickup truck population.
Sure,compound structures are the most complicated forms,most difficult to create tooling for,most expensive.But if you want the best quality fluid flow over a structure,you're hard pressed to beat them.
And if you ever intend to have all available kinetic energy transformed back to static pressure,and achieve lowest drag,you're pretty much locked in to using these forms.
Anywhere,except the automotive industry,will you find anything but these complex forms being used to eek out every bit of available energy when moving structures though fluids,be they gases or liquids.
Okay,rant over.Thanks Brett.
Old 01-22-2011, 07:37 PM   #10 (permalink)
90 day: 19.36 mpg (US)
A good read, all the way through.
