Old 02-28-2009, 03:47 PM   #221 (permalink)
Cd
Ultimate Fail
Cd's Avatar
So, basjoos, does this new low Cd figure improve the .17 figure that you arrived at ?
I never saw any of your coast down testing that you did to arrive at that figure. Did you create a seperate thread, or did I just miss it ?
Also, what is the cars Cd ( yes I know ...point 17, but I mean like .171 or .179 )
Old 02-28-2009, 05:48 PM   #222 (permalink)
basjoos's Avatar
Aerocivic - '92 Honda Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Honda Civic CX
90 day: 55.14 mpg (US)
Camryglide - '20 Toyota Camry hybrid LE
90 day: 65.83 mpg (US)
The changed OEM Cd figure has no effect on the 0.17 figure since that was determined by coastdown testing done using that spreadsheet from Instructables. Actually my Cd might even be a bit lower than that now as I have installed a number of minor aero mods since doing that coastdown testing. The problem is finding a long enough, flat, and lightly trafficked stretch of road to do the testing on. Its all rolling terrain here, so I have to make a trip down to the coastal plains of SC to do it.
I'd have to pull my original data points out and plug them back into that spreadsheet to get the 0.00 CD figure, but that might be false accuracy since my original data was to the nearest second, not the nearest 0.1 sec.
aerocivic.com
Old 02-28-2009, 09:11 PM   #223 (permalink)
Thanks for clarifying how you got the Cd figure. BTW, does the AeroCivic have a full belly pan as well?
Old 02-28-2009, 11:50 PM   #224 (permalink)
Grasshopper
alohaspirit's Avatar
Makai - '01 Toyota Echo 4D Auto
90 day: 34.45 mpg (US)
New Galaxy - '07 Toyota Prius
90 day: 42.15 mpg (US)
Everytime I see the Aerocivic I think how cool it would be to see it fully glassed and molded
(maybe even in carbon fibre)
Get rid of all those seams and you could probably knock off .01 or .02
Past Present Future?
Old 03-01-2009, 07:30 AM   #225 (permalink)
basjoos's Avatar
It has a full belly pan. The only parts of the underside that are still exposed to the airflow are the interior side of the wheels. I am still working out a mechanism that would shield the inside edge of the wheels from the wind while not interfering with suspension travel or front wheel turning.
It would be nice is my car's exterior were done in glass, but I don't have any experience working with it and don't have the climate controlled garage it would take to cure epoxy in my humid climate.
aerocivic.com
Old 03-01-2009, 08:36 AM   #226 (permalink)
Hi,
I'd assumed it probably did, because any vehicle with a Cd below 0.2 has to, I think.
Can you link to an explanation of the coast-down procedure to measure Cd, please?
Old 03-01-2009, 10:48 AM   #227 (permalink)
basjoos's Avatar
Measure the drag coefficient of your car
aerocivic.com
Old 03-03-2009, 12:18 PM   #228 (permalink)
Basjoos, I was actually searching for some help with an odd windshield wiper issue on my old '98 Civic and stumbled in..... Just wanted to say beautiful job on the AeroCivic!
Regards,
Tom ~ WV6Z in Anderson, SC
Old 03-03-2009, 05:44 PM   #229 (permalink)
basjoos's Avatar
Regards,
Hey, a neighbor! I've driven through Anderson a few times in my Aerocivic and visited a small Honda repair shop in the west end of town one time to get some parts. When I pulled into the shop, the mechanic said it looked like the martians were landing as I silently rolled up their driveway with the engine off.
aerocivic.com
Old 03-03-2009, 05:54 PM   #230 (permalink)
basjoos's Avatar
Added another minor aero tweak. I took a page out of Aptera's book and installed ducts to exhaust my cabin air into the small low pressure eddy behind the license plate. I doubt I will notice any difference in mileage, but every little bit helps and it should help to move the cabin air with less fan assist.
Vent holes at back of cargo area.
Other end of ducts opening into area behind license plate.
License plate installed with 1/2" gap behind plate.
aerocivic.com
aero mods-data-% change or Cd change ( installment # 7-Wheels/Tires/Wheelcovers/etc. aerohead Aerodynamics 5 06-04-2014 12:14 PM
[aero-mods(aft-body streamlining/boat-tails)Part-3 History/Timeline cont'd aerohead Aerodynamics 10 08-13-2010 12:50 AM
mods-data-% change or Cd change( installment#5-roofline data) aerohead Aerodynamics 3 09-26-2009 02:01 PM
Build Thread Key Postings Index Experiment. TestDrive Forum News & Feedback 7 02-15-2009 08:53 PM
Drafting and Cd reduction basjoos Aerodynamics 5 12-06-2008 10:45 PM
