Old 02-05-2014, 05:53 PM   #21 (permalink)
I bet the sports car had better braking ability...
Looks like he didn't...
Old 02-05-2014, 11:46 PM   #22 (permalink)
I second this. Make something you are proud of, but make something. Too many people talk. Too few people actually do anything.
Currently I'm waiting on the Washington State bureaucracy to decide what will be necessary for them to license a trike (legally motorcycle here) with home built or modified frame and front suspension. They're working on it . . .
After the feedback to this thread I'm pretty sure I'll do the narrow body with front wheels outboard.
I'm also not yet certain about the donor machine (almost certainly motorcycle in the 125 to 250cc range) nor about the front suspension.
The front end that looks best at this point is that designed for and used for the California Commuter, 1980. There are some issues with that. It's light weight, simple, and relatively easy to build, but uses very old Honda cycle/scooter wheels with drum brakes. Unfortunately I don't see how to adapt it to more modern wheels with disc brakes . . . I'd love to find a very simple front end design using readily available and reasonable cost more modern parts that is equally light-weight and otherwise suitable. Perhaps that will be a new thread somewhere on the ecomodder forums.
Old 02-06-2014, 06:09 PM   #23 (permalink)
front end design
I GOOGLED 'street legal 3 wheelers for sale' and a bunch of info came up.
You might be able to score something with a valid VIN number,which satis
fies some of your engineering requirements,then modify it to your taste,knowing that most of the mechanicals are pre-approved by Caesar.
Just a thought.
Old 02-06-2014, 10:49 PM   #24 (permalink)
Another complication of outboard wheels apparently, is in crosswinds, there is more drag than with a single unified body.
Old 02-07-2014, 01:38 PM   #25 (permalink)
3-Wheeler's Avatar
AlienMobile - '00 Honda Insight
90 day: 80.05 mpg (US)
......After the feedback to this thread I'm pretty sure I'll do the narrow body with front wheels outboard.....
The narrow body also has the advantage of being shorter for the same Cd.
As Phil mentioned earlier, the Cd of a full body may be better, however having shorter bodywork has advantages too.
Edison2 spent a lot of time determining which body configuration to go with, also decided on outboard wheels with skirts.
Jim.
The Following User Says Thank You to 3-Wheeler For This Useful Post:
aerohead (02-07-2014)
Old 02-07-2014, 03:51 PM   #26 (permalink)
Focus - '05 Ford Focus tdci Futura
I have an idea. Look at this MEV Eco-Exo | Exomotive – US Dealer of Exocars & Kit Carshttp://it is based on a suzuki burgman. Solid frame en simpel front susspention. And on that frame it would be easy to make an aero body for it. Also the wheel fenders would be easy to make on thet frame
The Following User Says Thank You to NickelB NL For This Useful Post:
Old 02-07-2014, 05:05 PM   #27 (permalink)
Sylph
Here's a couple of images that Neil posted for us of "Sylph" in the Cal Tech tunnel,from Jime57's thread: Some Scratch Build Ideas
Sorry,I couldn't link it.They're on page one of that thread.
The way the front wheels were done might be of interest.
Let's try this,
http://farm8.staticflickr.com/7106/6...b92f7f01_z.jpg
Old 02-08-2014, 02:29 AM   #28 (permalink)
I'd go with '...for the same fineness ratio.'
I know—pedantic.
Does a solid wheel act like a rudder compared to a wire wheel? Does the wire wheel have lower crosswind drag? Just asking questions.
If the wheels are ahead of the stagnation point of the main body, the 'biplane' interference is halved; if they are behind the stagnation point one or the other is shielded from the crosswind by the main body.
I should do an illustration of the front fender that been rattling around in my head. It could apply to a lot of different situations. If I say 'baloney-cut Indian front fender' does that paint a picture?
Old 02-08-2014, 07:12 AM   #29 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
In cycling, disk wheels are much more suceptible to cross wind forces. I believe this is the main reason they're banned from group events. You'll generally only find disc wheels on the rear of bikes for cross wind stability reasons. They certainly could 'steer' a bike, but that's mainly down the the steering geometry, which wouldn't be much of an issue on a car.
Old 02-08-2014, 12:48 PM   #30 (permalink)
Because cars have camber and toe-in where bikes don't?
