01-30-2010, 01:30 AM
#21 (permalink)
Pokémoderator
moonmonkey -
Originally Posted by moonmonkey
cfg83 is there any more to post from that article? have'nt found it on the web yet, noticed the front strake is flat on the inside edge , great info!
It's a magazine/book. There's too much to try to post everything. Here's the picture I said I would post for Old Tele man and thatguitarguy :
And here's the control logic :
CarloSW2
The Following 4 Users Say Thank You to cfg83 For This Useful Post:
01-30-2010, 04:28 AM
#22 (permalink)
aero guerrilla
Originally Posted by thatguitarguy
How about retracting automatically under speeds of 10-15 MPH, and then lowering into position when air pressure on the bow pushes them down at higher speeds. The faster you go the lower they get. After all, if you're hitting dips and driveways faster than 10-15 MPH, you're not an ecomodder anyway.
I'd drop them when the vehicle exceeds 25mph, then retract when the speed is below 15mph.
I wonder how the mechanism would work in a mud/cold/snow/ice/salt environment? The area around the wheels gets the most snow/mud build up.
eˇcoˇmodˇding: the art of turning vehicles into what they should be
01-30-2010, 05:54 AM
#23 (permalink)
as far as tire fairings go i used to run something made out of linuleum
basically the shape was formed by the dimentions of the sheet and the way it was attached, but if it hit anything it would deform and take it's original shape. aerodynamically my version didn't work well, so i ended up taking it off but technically the system worked well, it didn't reveive more than a few scratches on the bottom
aerˇoˇdyˇnamˇics: the science of passing gass
*i can coast for miles and miles and miles*
The Following 2 Users Say Thank You to lunarhighway For This Useful Post:
01-30-2010, 03:34 PM
#24 (permalink)
wall base
Originally Posted by Cd
The wall base looks 'factory' compared to the lawn edging I used to work with.Nice!
01-30-2010, 03:38 PM
#25 (permalink)
skirts
if you use these strakes, would side skirts help,or hurt,
If the rocker panels weren't already as low as the belly of the vehicle,then doing skirts would get one even with contemporary technology.
01-30-2010, 04:46 PM
#26 (permalink)
Originally Posted by lunarhighway
...aerodynamically my version didn't work well, so i ended up taking it off but technically the system worked well, it didn't reveive more than a few scratches on the bottom
A couple of questions:
Do you have any ideas about why it didn't work aerodynamically?
And, what is your belly pan made of? It's hard to tell in the photo, but it looks kinda like OSB?
01-30-2010, 06:32 PM
#27 (permalink)
Interesting detail on the Probe document.
"The use of a full length undercover body would incur unreasonable penalties in costs and weight and would not necessarily be the best solution"
Pete.
01-30-2010, 09:09 PM
#28 (permalink)
Ultimate Fail
Thanks Phil.
We sell that lawn edging that you guys use at Lowes, and the wall base is not only cheaper and more flexible, but also ( as you noticed ) has a "factory" look to it since it is actually made of rubber, versus shiny plastic.
01-30-2010, 09:17 PM
#29 (permalink)
Ultimate Fail
Can you reword that Phil ?
01-31-2010, 07:15 AM
#30 (permalink)
Unless I'm mistaken, Phil is saying skirts should be as low as the lowest point under the car.
