Old 01-31-2010, 11:25 AM   #31 (permalink)
ecomonkey
silver clown - '02 toyota echo 2 door base
90 day: 47.16 mpg (US)
white ghost - '05 prius base
90 day: 47.53 mpg (US)
white pearl - '12 toyota prius base
Last 3: 45.69 mpg (US)
that would make the ones on the aerocivic incorrect,, as i beleive they extend down much lower than the belly pan on his car, am i wrong?
Old 01-31-2010, 01:29 PM   #32 (permalink)
AeroModder's Avatar
Tank - '96 Ford Aspire 4 door
Team Ford
90 day: 46.75 mpg (US)
This Aerospeed article has a ton of helpful information, including trials of different shapes/sizes:
Modifying Under-Car Airflow, Part 2
Measurable on-road improvements from a custom front undertray
The Following 4 Users Say Thank You to AeroModder For This Useful Post:
moonmonkey (01-31-2010), Nels (01-31-2010), Piwoslaw (02-01-2010), Rokeby (01-31-2010)
Old 02-12-2010, 03:06 PM   #33 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Basjoos' skirts are actually a pair of skirts on each side of the car, the width between each set is the width of the tire(s). He's aiming for a "catamaran" approach.
Old 02-13-2010, 05:43 AM   #34 (permalink)
vectra a - '95 Opel Vectra GLS
90 day: 37.51 mpg (US)
@ thatguitarguy
Originally Posted by lunarhighway View Post
...aerodynamically my version didn't work well, so i ended up taking it off but technically the system worked well, it didn't reveive more than a few scratches on the bottom
A couple of questions:
Do you have any ideas about why it didn't work aerodynamically?
And, what is your belly pan made of? It's hard to tell in the photo, but it looks kinda like OSB?
sorry to be so late to respond.
the original undertray in that picture was made from aluminium, and has since been replaced with coroplast.
i'm not sure why the dams didn't work but i think it's because they didn't cover enough tire with but to much tire height, as well as to much of the wheel well was covered.
it's not like they killed milage but i found no indication either in preceived driving behaviour as in actual FE
i must say however i only use tank to tank results so evaluatings mods like this is not very accurate to say the least.
i think the main thing with these fairings is that they cover the full width of the tire.
most older cars have bumpers that curve in and leave the lower outer portion of the tire exposed.
i'm curently running wheel dams as seen on many todays cars, with dimentions derived from measurements (1/6th tire height ground clearence below the dam) the dam coveres the inner half of the tire as well as part of the wheel well, but in front of the whell they curve backwards.
also seen from the sides the dams curve backwards slightly,
these dams "appear" to help as the car "feels" better to drive and will coast further. the weather is such however (snow and freezing) that i can't vouch for their effectivenes
aer·o·dy·nam·ics: the science of passing gass
*i can coast for miles and miles and miles*
List of aero mods you can do to your vehicle MetroMPG Aerodynamics 148 08-12-2021 10:53 PM
Flashing yellow light skyl4rk EcoModding Central 5 08-01-2010 01:57 PM
News: VW to unveil 70 mpg (US) Golf diesel hybrid MetroMPG Hybrids 27 06-29-2010 07:50 AM
Sources of Aerodynamic Drag in Automobiles and Possible Solutions SVOboy Aerodynamics 12 02-17-2010 02:09 PM
Tire Engineer here - concerned about hyperinflating tires CapriRacer Introductions 48 09-26-2009 09:25 PM
