Old 02-25-2011, 06:38 PM   #141 (permalink)
spring effect
Hmmm, I missed that part of the discussion, I guess. It is odd to think that the air is "bumped" out of the way and has a spring affect? One would think that a given volume moves out of the way a given distance, and then moves back.
There must be a repelling force between the molecules in the air that is acting as a spring. So, it is not just the static volume of air that gets displaced, but rather the speed and shape of the front that has a lot to do with it.
So, then the shape of the front does have an indirect affect on drag -- blunt front ends "punch" the air harder, and may *improve* the air flow on the trailing side, by creating higher pressure? But at high(er) speeds, this leading pressure wave becomes critical, and the front must be pointy to split the air, rather than "punch" it?
I think 'spring' is a pretty good analogy in this perverted sense.The atmosphere is a valve-lifter and spring pushing against a camshaft,or breaker block in an old distributor.
There is a rpm at which the spring is unable to close the valve or maintain contact between the breaker-points rubbing block and distributor cam,and you'll have 'float.'
If the body of a car's aft-body drops off too suddenly,the air 'spring' of the atmosphere will be unable to prevent 'float' resulting in separation.
Old 02-25-2011, 07:19 PM   #142 (permalink)
Recreation Engineer
KamperBob's Avatar
Black Stallion - '02 Toyota Tundra 4WD xCab
Half Pint - '06 Yamaha XT225
Nice rule
Neil,once the boundary layer goes over to turbulent the Cd is fixed for a body up until around 250-mph for cars,when compressibility issues come into play. Angles, good at any sub-transonic velocity will not alter drag anywhere within this velocity domain.
In fluids,the barometric pressure will affect air density,which is part of the drag equation.
The pressure drag,which is what we're going after,is ruled by separation.If you can eliminate separation you've eliminated pressure drag.
If you get an angle which will work at 25 mph,she'll still be good at 225.
That is a nice rule of thumb. The 25-250 mph regime is good to know. I thought that was about the lower bound but had no idea about the upper bound. Thanks, Phil!
Recreation Engineer
Old 02-26-2011, 04:48 PM   #143 (permalink)
AeroModder's Avatar
Tank - '96 Ford Aspire 4 door
Team Ford
90 day: 46.75 mpg (US)
While doing some overlay work, I've noticed that the template is actually tilted slightly. The base isn't quite level. The base of the template is tilting up at the rear by about .6 degrees, according to GIMP's measure tool.
Here's the rotated image:
I found the tilt when overlaying the template to a 3rd gen Prius, since I'm using it as inspiration for my Aspire project. I'm thinking if the Prius goes a bit steeper than the template and still manages good flow, maybe I can get away with something similar.
The image of the Prius wasn't level either, but I tweaked the images to work. I didn't make it level, since it was making it look distorted.
In Reason we Trust
The Following User Says Thank You to AeroModder For This Useful Post:
aerohead (02-28-2011)
Old 02-26-2011, 05:08 PM   #144 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
AeroModder -
I already took that into account in earlier posts. Here's post #119 with a super-clean image for transparency overlays :
http://ecomodder.com/forum/220442-post119.html
CarloSW2
American Solar Energy Society
The Following User Says Thank You to cfg83 For This Useful Post:
Old 02-26-2011, 05:34 PM   #145 (permalink)
AeroModder's Avatar
Team Ford
Sorry, I missed that. I thought that it was just the numbers that were cleared up.
In Reason we Trust
Old 02-26-2011, 10:29 PM   #146 (permalink)
Here's an interesting comparison:
aerohead (10-13-2012)
Old 02-27-2011, 08:53 AM   #147 (permalink)
LUVMY02CREW's Avatar
TANK the fifth - '02 Chevrolet S10 Crew Cab 4x4 LS
90 day: 20.44 mpg (US)
OK, so I've been scanning through this thread and need some answers to help my brain wrap around this streamline template thing so I can do some figuring with my truck......
Is this template from post 119(as shown by cfg83) the correct/best to use for a side shot?
Is this template from post 95(the double one) the correct/best to use to look at from the top?
What software do I need to use to be able to make this happen? and can it be downloaded from cnet.com(I've read good things about that website)
Thanks for any help...
Old 02-27-2011, 12:03 PM   #148 (permalink)
AeroModder's Avatar
Team Ford
The double one is pretty much taking a full teardrop and adding the ground in straight down the middle. It's used in the same way. The newer template is edited so it's easier to use and understand.
As for software, I use GIMP, a free art program. It takes a bit of getting used to, but it's quite good.
In Reason we Trust
Old 02-27-2011, 01:40 PM   #149 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
LUVMY02CREW -
That is a good question. I think that aerohead should pick from among *all* of our templates, and a moderator can modify the first post to show *the* best image for the job.
In terms of the image I created, the main benefit is that it has the 0.6 degree rotation/correction that aeromodder pointed out and I reduced it down to a 2-color image. That means it works well in a transparent overlay.
CarloSW2
Old 02-27-2011, 08:27 PM   #150 (permalink)
AeroModder
- Just to be sure I'm not confused, would you please clarify what you meant by "The newer template is edited"...was it the double template that I reposted or another one that I missed????
- AND thanks about the "GIMP" software, I looked into that a bit earlier and that might be the way I go...free stuff is great
cfg83
- I agree that it would be helpful if aerohead and the mods could update and clarify which to use. Everyone "reading off the same page" can only be a good thing in the long run.
Maximum angle for boat tail? abcdpeterson Aerodynamics 80 11-03-2021 12:55 PM
Aerodynamic Streamlining Template Part-B aerohead Aerodynamics 8 05-31-2013 12:23 PM
LED Headlight captainslug DIY / How-to 82 11-15-2011 01:32 AM
Aerodynamic Streamlining Template: Part-A aerohead Aerodynamics 0 07-18-2009 02:37 PM
All items I scanned in the new product showcase dremd The Lounge 0 11-08-2008 04:14 PM
