Old 05-29-2013, 05:40 PM   #541 (permalink)
I've read though a few important posts to get the intent of use out of the template. From what I can tell, it was originally intended to be used as a "quick and dirty tool", a start in the right direction for most.
Aerodynamic Streamlining Template: Part-A
http://ecomodder.com/forum/showthrea...part-9285.html
Premise: The template is designed to be a quick and dirty reference for anyone contemplating aft-body streamlining to an existing vehicle or from a "body in white.
Aerodynamic Streamlining Template Part-B
http://ecomodder.com/forum/showthrea...rt-b-9286.html
-------------- Those with more advanced aerodynamic toolbags will will no doubt venture out into some of the more exotic shapes,but for amateurs,I believe this form can serve us well.------------------------------------------ Good design and engineering calls for the bare minimum to get the job done........
Aerodynamic Streamlining Template: Part-C
http://ecomodder.com/forum/showthrea...-c-9287-2.html
(1) The ratio does not vary with speed,as it is fixed by the critical Reynolds number which for cars,occurs at about 20-mph.At 20-mph and above,you've established the turbulent boundary layer and Cd minimum which remains constant up to the beginning of transonic flow,at about 250-mph.---------
If I can make a request, when it comes time to do a "Part-D", that it be 3D and include cross sectional information.
There was a thread to turn it into 3D, I'll find it later if someone else does not post it first.
Old 05-29-2013, 09:55 PM   #542 (permalink)
Possibly this one?
Why does The Template have to be a half body of revolution?
Old 05-30-2013, 07:15 AM   #543 (permalink)
aardvarcus's Avatar
Deep Blue - '94 GMC Suburban K2500 SLE
90 day: 23.75 mpg (US)
Griffin (T4R) - '99 Toyota 4Runner SR5
90 day: 25.43 mpg (US)
I have been playing with the “new” template, and it appears to be a very close match to the roofline of a seventh generation Toyota Celica. I did a rough PowerPoint overlay using a Celica off the internet. Thank you Aerohead and ChazInMT for all your work in giving us these tools to work with, it is very helpful.
Name:	AST2 Celica - Resize.jpg
Old 05-30-2013, 04:57 PM   #544 (permalink)
3D
Many months ago someone pushed and I went ahead a posted some extra views of the 'Template' I'd been working on.These were just working drawings.
I'm not sure how the thread was even titled.
A literal 'translation' of the 'Template' would be the 1/2-body generated from the 2.5:1 streamlined body of revolution from which it is derived.
It would be 'wide.'
Considering 'conventional ' body dimensions,the plan-view of the 'template' will look more like the low-drag 'section' profile of Hoerner's just to accommodate the more narrow vehicle.
Old 05-30-2013, 05:01 PM   #545 (permalink)
Celica
It looks really good!
You'd have an easier time than most pushing that puppy into significant low-drag territory.
Nice project car!
aardvarcus (05-31-2013)
Old 05-30-2013, 05:08 PM   #546 (permalink)
betasniper's Avatar
Red - '01 Honda Insight CVT
Gen-1 Insights
House of Tudor
90 day: 59.17 mpg (US)
Civic Hybrid - '12 Honda Civic Hybrid
Bahamut - '18 Chevrolet Volt LT
Team Volt
Plug-in Hybrids
How would this airfoil fair?
Link has plot data. Has an aftbody ratio of 1.833 (bit long) but this airfoil looks a bit too fast at the start. Havent compared it to new template yet, as I am on my tablet right now, but earlier on the computer I compared to old template and it seemed way faster and longer.
Name:	863 Strut.JPG
: Brothers
: Dad's
Old 05-30-2013, 06:37 PM   #547 (permalink)
Aero Deshi
ChazInMT's Avatar
MagMetalCivic - '04 Honda Civic Sedan EX
Last 3: 34.25 mpg (US)
Looks good in the part that counts the most from top out to 50%, this is pretty ideal.
Bigger Version
The Following User Says Thank You to ChazInMT For This Useful Post:
aerohead (05-30-2013)
Old 05-30-2013, 06:45 PM   #548 (permalink)
how would
I would compare it to Mair's boat tail.
He used about one body diameter length to curve his body into a 22-degree slope,and then just maintained a constant slope as in your rendering.
The 'straight' conical sections are easier to fabricate but must be reinforced from the inside,as they have no eggshell strength of the compound curve and will 'tin can'.
Old 05-30-2013, 08:39 PM   #549 (permalink)
I saw that one, it turns up in a search and I think that I've referenced it at some point - thanks.
I remember the images, a nice blue 3D teardrop with a tight black wire grid over it. It sort of looked like the spaceship Moya in the Sci-Fi cable TV show called Farscape.
Farscape's Leviathan Moya - WIP - Scifi-Meshes.com Gallery
aerohead (03-12-2016)
Old 05-31-2013, 02:30 AM   #550 (permalink)
Bless you. Do this:
My ability to help you ends there.
aerohead (06-01-2013)
Maximum angle for boat tail? abcdpeterson Aerodynamics 80 11-03-2021 12:55 PM
Aerodynamic Streamlining Template Part-B aerohead Aerodynamics 8 05-31-2013 12:23 PM
LED Headlight captainslug DIY / How-to 82 11-15-2011 01:32 AM
Aerodynamic Streamlining Template: Part-A aerohead Aerodynamics 0 07-18-2009 02:37 PM
All items I scanned in the new product showcase dremd The Lounge 0 11-08-2008 04:14 PM
