Old 12-11-2012, 10:45 PM   #1 (permalink)
air dam material???
what is the cheapest/best air dam material to experiment with? Looking to build a secondary air dam to offset some of the losses from the lift (2005 Ram diesel 4x4)
Old 12-12-2012, 01:31 AM   #2 (permalink)
Jimmy - '00 GMC Jimmy SLT
90 day: 21.18 mpg (US)
The White Gnat - '99 Suzuki Swift
Team Suzuki
90 day: 51.87 mpg (US)
A few people on here talk about "lawn edging". I've never tried it myself, but it seems like a reasonable idea if your project will be staying within it's limits.
Old 12-12-2012, 01:48 AM   #3 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Conveyor belt is good too. It's very tough. I've dragged mine on the road plenty of times with no damage.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
Old 12-12-2012, 02:12 AM   #4 (permalink)
The lawn edging wouldnt be wide enough. Would the conveyor belt be stiff enough??? Havent measured it yet but i think it would need to be about 8-12" wide and about 4' long
What im thinking is a 2 piece setup, 1 piece mounted permanantly and the 2nd piece would bolt to it allowing me to play with height and shape. Wondering what would be strong enough to hold its shape under there
Old 12-12-2012, 03:38 AM   #5 (permalink)
rafaelsmall94's Avatar
Thumbs up
Why don't you try a metal rod already. The 2 piece setup/idea is great. On the other hand conveyor belt seems pretty handy in the situation. I guess trying both the methods or even hybridizing them may get the job done.
Sorry, new users are not permitted to post links in their signatures.
Old 12-12-2012, 08:46 AM   #6 (permalink)
Busting Knuckles Often
Blue Maxx - '04 Chevrolet Malibu Maxx LT
Team Chevy
90 day: 26.96 mpg (US)
Tink's Van - '08 Chrysler Town & Country Touring
90 day: 19.09 mpg (US)
2004 5 Speed Goldrolla - '04 Toyota Corolla CE
90 day: 36.3 mpg (US)
Thumbs up Just don't increase your frontal area too much
Originally Posted by steve05ram360 View Post
The lawn edging wouldnt be wide enough. ... but i think it would need to be about 8-12" wide and about 4' long
Many more people smarter than I (aerohead, etc.), have always said there is a sweet spot in air dam sizing, too much does more harm than good, or is of neutral value.
Great thread here:
http://ecomodder.com/forum/showthrea...tml#post252900
I referenced figure A and B when deciding to just do a dam in front of my tires for now, leaving the center open, and maybe do a belly pan in the spring. YMMV of course, the tough part is, there are some general rules of thumb that get quickly complicated because each vehicle is so different underneath.
I like the double section, hinging idea. I was thinking about hinging even for a single section one, but decided on my spats / airdams in front of tires just for now:
http://ecomodder.com/forum/showthrea...tml#post333461
Old 12-12-2012, 09:39 AM   #7 (permalink)
http://ecomodder.com/forum/showthrea...ing-17399.html
Old 12-12-2012, 11:31 AM   #8 (permalink)
You can see the 6" deep lawn edging material I used, a link is in my signature below.
After several Michigan winters it's starting to crack along the top bead. It's been on since March 2009, hope to make to 4-years next spring.
I've mended a tear in it when I spun and hit a snow/ice pile with some 2-part epoxy glue and a lawn edge patch on the back side.
I went over a curb while backing up when I cut my wheels to early, need to repair that now.
The guys on the race track use conveyor belt material for a reason, it can take a beating (but costs and weighs more).
Chin Spoiler:
http://forums.pelicanparts.com/off-t...effective.html
Rear Spoiler Pick Up Truck
http://forums.pelicanparts.com/off-t...xperiment.html
Roof Wing
http://ecomodder.com/forum/showthrea...1-a-19525.html
WesternStarSCR (12-12-2012)
Old 12-12-2012, 12:48 PM   #9 (permalink)
Yeah I saw that thread of yours with the S10. I could probably find a way to make that work by making the brackets extend down lower. I will go have a look. Thanks guys!
Old 12-12-2012, 01:40 PM   #10 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
I use 3/8" ripstop conveyor belting.
My air dam is about 24" wide and is partially supported by a couple of aluminum plates.
Expensive. Hard to work. Nearly indestructible. Impervious to heat, cold, gasoline, road kill, curbs, etc. Had mine on the truck for five years now.
When I have to replace it (who knows when? - it looks A-OK) next time I'll make a paper pattern, pay the shop rate and have it sheared and punched by a pro.
Grade clearance is an issue I'm afraid only a wind tunnel can give you an optimum answer. For a while I had full-width 3" ground clearance. Looked dorky and ground everytime I stopped but gave the best MPG. Now I have 6" grade clearance in front of the tires and 10" between (just covers the steering. Looks better, never grinds and doesn't give as good MPG.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
The Following 2 Users Say Thank You to Big Dave For This Useful Post:
mcrews (12-14-2012), WesternStarSCR (12-12-2012)
