Old 11-01-2016, 08:28 AM   #1 (permalink)
VW GOLF - '96 Volkwagen Golf MK3 GL
90 day: 50.21 mpg (US)
Commute scoot - '95 Suzuki AE50 Style
Last 3: 70.4 mpg (US)
The German - '99 Mercedes W202 C200 Classic
90 day: 27.65 mpg (US)
Air dam or no dam - and height?
Morning all,
I just got my new car and it does 20mpg (US) - so, improvement is required!
I want to add an air dam on the front, but the front is not a consistent height. The bottom lip of the bumper is divided into thirds.
The outer two thirds have a ride height of 20cm (7.9in) and the centre third is higher at 24cm (9.4in).
Now, I wonder whether the centre third being higher is actually helping air get under the centre of the car at a lower pressure (and so less drag).
I also wonder whether an air dam going as low as I can 10cm or less, depending on local roads. is the answer?
Will you recoup money spent on mods in fuel saved? see my spreadsheets here
Old 11-01-2016, 08:34 AM   #2 (permalink)
Aero Deshi
ChazInMT's Avatar
MagMetalCivic - '04 Honda Civic Sedan EX
Last 3: 34.25 mpg (US)
The less air under your car, and the more air you can get to go around the sides, the better. Over the top of the car is 2nd best, with sides being preferred. Can you post a picture of what you're talking about? Preferably at about ground level around a foot above looking at the spoiler area in question.
Old 11-02-2016, 01:00 PM   #3 (permalink)
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
In the simplest terms, total drag is coefficient of drag (Cd) times area (A). The underside of a car is very aerodynamically dirty, and an air dam increases frontal area (A) to direct air away from the underside, significantly improving the coefficient of drag (Cd). A belly pan can reduce Cd without increasing area. I imagine the less air going under the car the better, but it might not actually work out that way on some vehicles with huge ground clearance.
Old 11-02-2016, 06:54 PM   #4 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Sometimes, manufacturers design things just to look sporty so it will influence the buyers in buying the vehicle. Look at the rear diffuser designs on modern sedans as an example.
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following User Says Thank You to BamZipPow For This Useful Post:
aerohead (11-05-2016)
Old 11-02-2016, 08:01 PM   #5 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
IIRC the Opel Calibra which had a very low drag for it's time had such a set up (0.27cd?).
Perhaps @Aerohead can explain, otherwise I'll check if Hucho says anything about it.
The Following User Says Thank You to oldtamiyaphile For This Useful Post:
Old 11-03-2016, 08:37 PM   #6 (permalink)
Team Turbocharged!
Pickups
Hucho says Opel saved 0.003CD by cutting a ~930mm section from the centre of the Calibra airdam. Drag increased either side of this.
Hucho doesn't seem to go into detail as to the hows and whys of this.
Old 11-03-2016, 10:18 PM   #7 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
He does a little:
-"Apparently, by the former measure [the cutout in the airdam] the obliqueness of the flow to the front wheels was attenuated."
-"The central cutout in the spoiler may improve the flow at the end of the underbody, so that a diffuser can work more effectively."
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following User Says Thank You to Vman455 For This Useful Post:
Old 11-04-2016, 02:30 AM   #8 (permalink)
Consider also that a spat shielding the front of the tires is beneficial, but too low a center results in 'high-centering' on dirt and gravel.
Old 11-04-2016, 07:22 AM   #9 (permalink)
Thanks, so I guess I will have to test and see. I've measured up the length of plastic requred and will see if that matches my donor bumper, it's from a smaller car so maybe I'll have to patch it together at the ends or somthing.
@ChazInMT I've attached a picture as you asked. It's probably a Calibra-esque shape as it's from the same styling era.
I should also say that spats are factory-fitted in front of the front and rear wheels on this car.
Name:	2016-11-04 10.38.35.jpg
The Following User Says Thank You to sallen For This Useful Post:
Old 11-05-2016, 03:58 PM   #10 (permalink)
centre
A guess would be that the sides are acting as 'spats',limiting air access to the tires and hour-glass belly openings.
I don't have any specific data.
The other thing is that when you enter a driveway from the street at an angle,the reduced center height of the airdam may protect it from a ground strike when going over the vertical apex of the driveway ramp.A practical concession.
BamZipPow (11-05-2016), freebeard (11-05-2016)
