Old 05-09-2010, 03:22 PM   #21 (permalink)
Basjoos Wannabe
ShadeTreeMech's Avatar
The Van - '97 Mercury Villager gs
90 day: 19.8 mpg (US)
Lyle the Kindly Viking - '99 Volvo V70
90 day: 25.82 mpg (US)
can a paper filter clean down to X microns? Sure, and there's years of experience to prove it.
can a reusable filter clean down to the same x microns? theoretically yes. Will you gain power? maybe. Will it be more economical compared to a new paper filter? doubtful.
And what is most likely to fetch the most consistently high quality filtration, replacing a good quality paper filter or cleaning and reoiling the cotton filter? And what is the likelihood of getting oil on the hypersensitive MAF sensor?
Here's a discussion from a corvette forum on the issue. To be quite honest, a paper filter is inexpensive and nearly guaranteed to work 100% of the time, while the cotton filter requires maintenance to keep it working correctly.
Worst case scenario with a paper filter if you're a couple thousand miles behind on replacement is that the acceleration is less peppy. But with the cotton filter, you risk damage to the engine.
I personally don't like to take such chances with a good engine.
RIP Maxima 1997-2012
Originally Posted by jamesqf View Post
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
Old 05-09-2010, 03:32 PM   #22 (permalink)
Basjoos Wannabe
Here's a more scientific approach to the question
Old 05-09-2010, 05:16 PM   #23 (permalink)
AeroModder's Avatar
Tank - '96 Ford Aspire 4 door
Team Ford
90 day: 46.75 mpg (US)
I just put the K&N back in my car, and I'll see what the mileage is. I have several tanks with the Fram to compare it with.
By the way, reuseable filters help add less to landfills. There's eco for you. XD
In Reason we Trust
Old 05-09-2010, 05:29 PM   #24 (permalink)
sarguy01's Avatar
Mazda5 - '12 Mazda 5
90 day: 25.22 mpg (US)
Big D - '11 Dodge Durango Crew
90 day: 18.75 mpg (US)
It does add less to landfills, but what about when people degrease them in their driveways and the old oil runs off into the street?
Old 05-09-2010, 10:01 PM   #25 (permalink)
mwebb's Avatar
no nickname , it's just a car - '04 volkswagen golf tdi
speed density
The car they used had a MAF (Mass air flow) sensor and a turbo. My car has a MAP (Manifold absolute pressure) sensor and is naturally aspirated. Results vary.
speed density systems or
systems with Manifold Absolute Pressure MAP sensors
might actually get slightly IMPROVED FE with a clogged or restricted air filter as
MAP = Baro minus intake vacuum ,
and a restricted air filter will INCREASE intake vacuum and DECREASE the MAP value . and since MAP is the primary load sensor
AND
an increase in intake vacuum will DECREASE fuel pressure
all else the same less MAP = Less fuel injected
of course Mr 02 sensor will correct the mixture to 14.7 to 1
but
the ignition timing map will now measure with slightly less load
and too many variables to predict .
bottom line -
a clogged or restricted flow air filter WILL NOT DECREASE FE in a speed density system
Old 05-10-2010, 07:04 PM   #26 (permalink)
Basjoos Wannabe
I can often extend the life of a paper filter simply by knocking off the loose dust from the exterior of the filter. (There's a lot of dust in my area.)
Has anyone messed with cyclonic dust removers? (I'm referring to a device that removes dust from the air like a Dyson vacuum.) I've heard of them, and seen some examples in heavy equipment, but not in passenger vehicles. Using a device of that sort before the air filter would certainly extend it's life, or even using a foam filter in front of the paper filter.
Reuseable filters are a good idea, but they need to be a bit more sophisticated than a porous collection of cotton fibers. I've seen some reusable filters in vacuum cleaners that are reusable, but look very similar to a traditional paper filter. I would love to have a reusable filter that i could trust, but the K&N variety is a type I don't trust.
Old 05-19-2010, 07:12 PM   #27 (permalink)
slave to the grind
TOOQIKK's Avatar
Sippy The Slow Sentra - '94 NISSAN SENTRA EX
90 day: 45.73 mpg (US)
Send a message via AIM to TOOQIKK
Cool
check out the links in my next post they show some facts about filters and there is an informative video in the second on....
Old 05-19-2010, 07:15 PM   #28 (permalink)
slave to the grind
TOOQIKK's Avatar
little video for ya'll
The Following User Says Thank You to TOOQIKK For This Useful Post:
viio (05-20-2010)
Old 05-20-2010, 10:48 AM   #29 (permalink)
Project EconoPolo - '04 Volkswagen Polo Twist TDi
90 day: 48.23 mpg (US)
Nice video link!
Old 05-23-2010, 04:54 AM   #30 (permalink)
The PRC.
Funnily enough yesterday I took mine out, knocked a load of dust out of it and then stuck a hoover (vacuumn cleaner) nozzle over it and it looks almost new. I'm hoping that reduces the recent smoke under full throttle issue I've been having, otherwise its the turbo. Maybe.
Comparing Warm Air Intakes (WAI) & Cold Air Intakes (CAI) toomuch EcoModding Central 27 11-20-2022 04:24 PM
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
The Mechanism Behind Flow Separation LostCause Aerodynamics 46 07-15-2010 07:38 AM
Moving air intake into the engine compartment? pasadena_commut Aerodynamics 5 07-25-2008 03:24 PM
Broken Air Filter Discovered RH77 Off-Topic Tech 2 07-03-2008 10:14 PM
