Old 08-21-2008, 11:51 AM   #11 (permalink)
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
I have often heard that you only need about 8 hp to go 55 mph.
My motorcycle is using a 8 hp continuous electric motor. It is geared for 45, but a gear swap would let me go 55.
Who needs 100 HP really!
Yeah, I am not saying turning off DRL will save a ton, but every little but helps!
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 08-21-2008, 12:54 PM   #12 (permalink)
This is a spreadsheet I made up a while back using information from an autospeed.com article. It estimates how much HP you need to go a certain speed. Its not incredibly accurate, but it gets you close. Just fill in the yellow cells to get your answer.
HP_at_Speed_calc.xls
Old 08-21-2008, 06:55 PM   #13 (permalink)
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
I'm running two Deep cycles and just drove from Vancouver to Seattle in my Previa. Batts were at 60% DOD when I got there. This included about twenty starts in the border line up (45 minutes of idling saved) They are used series 27 batteries @ $50 ea. from a local shop.
Another thing to remember is that your alternator is also charging your battery. It has to recharge each time you start and trickle charges constantly. I have never seen a battery take less than 3 amps after sitting overnight and it would be much more after you just pulled 400-500 amps to get it going. All this at a time when engine is cold and running rich.
Now that my Previa is alternator free it starts easier , has more pep and revs quicker. Not to mention getting 26 mpg highway (20mpg EPA)
Read what the experts have to say about alternator loads:
IEEE Spectrum: Automotive Electrical Systems Circa 2005
Cut that gas hog out of there.
P.S. Guess who was instrumental in getting DRLs into cars? (Hint: EV killers)
G.M. *******s.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
Old 08-21-2008, 07:21 PM   #14 (permalink)
Tracy - '00 vauxhall corsa
heres an idea. the alternator is controlled by voltage. if we have an alternate charge source to the alternator then the voltage will go high and the alternator will switch off eliminating parasitic load. all we need is a big 110v battery and a charger. we can control the rate of charge with a resistor (light bulb) in series with the car battery or the internal resistance of the battery itself. we don't even have to supply all the amps -if the voltage drops the alternator will kick in.
Nissan Leaf 24kwh. Average FE = 300mpg 3.6miles/kwh (@plug)
Old 08-21-2008, 07:50 PM   #15 (permalink)
orange4boy's Avatar
90 day: 57 mpg (US)
Not a bad idea if you don't want to remove your alt completely
If that's true, you would reduce the electrical load on the alternator but the belt still adds some drag.
Two 8 volt golf cart batteries in series would net you 16+ volts. You would have a good buffer until the alt kicks in.
There are also 16v racing batteries for just this application (they know how to get every bit of efficiency) but I don't know if they are deep cycle or not.
P.S. you don't want your alternator to try to charge a deep cycle battery!!!! You might burn it out trying to supply all those amps.
Old 08-21-2008, 08:00 PM   #16 (permalink)
i have loads of batteries from my electric bike i may just wire them all up for 144v then put that through a switched mode power supply to get down to 15v. alternator switches off at 14.5v so i should be able to direct connect them without problems. diodes in the switched mode supply will stop alternator charging anything it shouldn't. i have every thing i need already. just need to find a battery +ve and -ve inside the driving compartment or push a wire through the fire wall.
Old 08-21-2008, 08:48 PM   #17 (permalink)
Brown Bus - '98 GMC Sonoma X-Cab SLS
90 day: 31.37 mpg (US)
Um, is someone suggesting a pulse and glide alternator? I don't understand.
Meh Truck
Old 08-21-2008, 08:52 PM   #18 (permalink)
This is one of those moments where I call BS for one of two reasons. Either to remind the population that not all cars work the same, or to put some real, hard data out there. This data point is slim.
The field coil on my alternator is controlled by the computer. The field coil is not activated during starting. If I were to observe faster starting during alternator disconnect, it would perhaps be due to what I call the "hydrogen generator placebo effect." Clearly it would be my active and optimistic imagination.
Meh Truck
Old 08-21-2008, 10:44 PM   #19 (permalink)
orange4boy's Avatar
90 day: 57 mpg (US)
With two big deep cycle batteries behind it...
Old 08-21-2008, 11:21 PM   #20 (permalink)
Gotcha. Yeah. So maybe it has nothing to do with the alternator removal as much as the dual battery status.
Meh Truck
Electric fifth wheel (DIY through the road parallel hybrid) friedlbug Hybrids 41 10-14-2019 10:22 PM
News: VW to unveil 70 mpg (US) Golf diesel hybrid MetroMPG Hybrids 27 06-29-2010 07:50 AM
Home Brew Challenge for Electric Geniuses (make a DIY electric motor controller) WaxyChicken Off-Topic Tech 42 08-19-2008 01:05 AM
Series Motor - Speed vs Torque TomEV Fossil Fuel Free 3 03-02-2008 12:27 PM
AC Induction Motor used as Brushless DC? WaxyChicken Fossil Fuel Free 5 01-29-2008 09:26 PM
