Old 09-27-2023, 08:47 PM   #1 (permalink)
blownb310's Avatar
Saab EV - '19 Chevy Bolt EV LT
Pierre - '07 ZENN MC2 Base
Aluminum Brake Rotors
Hypothetical situation for discussion. What if I cast and machined aluminum brake rotors to duplicate the cast iron ones on a 3,700 lb. Bolt EV?
EVs barely use the brakes. In the salt belt, it's even difficult to keep the rust from forming on them. A Bolt EV has an enormous amount of regen capability and can come to a complete stop without touching the brake pedal. Even if a rare panic stop was needed, I don't think you would overheat the rotor from a single stop from less than 65 mph.
Is there anything I am overlooking?
2007 ZENN and 2019 Chevy Bolt EV 145,000 oil free miles to date.
Old 09-27-2023, 08:59 PM   #2 (permalink)
Compare CNC from a billet. What alloy do you propose?
Are they ventilated and/or cross-drilled? That wold complicate things.
Old 09-27-2023, 10:17 PM   #3 (permalink)
blownb310's Avatar
Probably just 6061. I see that Wilwood makes hard anodized aluminum brake rotors for sprint cars. So maybe that's how they get aluminum to last in a brake disc application.
The Bolt EV front rotors are common vented units, not cross drilled.
The Following User Says Thank You to blownb310 For This Useful Post:
freebeard (09-27-2023)
Old 09-27-2023, 10:38 PM   #4 (permalink)
These are OEM steel, on my Superbeetle. The cryogenic tempering cost about as much as the raw part.
https://www.thoughtco.com › cryogenic-hardening-2340006
Introduction to Cryogenic Hardening of Metal - ThoughtCo
Besides steel, cryogenic hardening is also used to treat cast iron, copper alloys, aluminum, and magnesium . The process can improve the wear life of these types of metal parts by factors of two to six. Cryogenic treatments were first commercialized in the mid-to-late 1960s.
Old 09-28-2023, 12:13 AM   #5 (permalink)
I only remember seeing aluminium disc brakes on motorcycles, yet since some Russian cars had aluminium rear drum brakes I wouldn't be surprised if the front discs were made out of aluminium too.
Old 09-28-2023, 08:42 AM   #6 (permalink)
Use carbon ceramic rotors. They are lighter than aluminum. Aluminum rotor will clog up the pad and grind up the rotor.
Aluminum brake drums have steel inserts.
blownb310 (09-28-2023)
Old 09-28-2023, 10:31 AM   #7 (permalink)
7075 alum, what we used to call armor plate still melts around 1500 degrees. I know there's other alloys, but, significantly pricier. Sprint cars don't use their brakes much during the race, going sideways tends to scrub off speed and the brakes are an ancient requirement from years past.
Old 09-28-2023, 10:52 AM   #8 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Depends how you drive, mainly the top speed. In most cases with evs will work without major problems.
You can calculate what thickness you would need when you know your top speeds and driving style. Meaning mill new brake pads thinner so you can fit thicker rotors if needed.
https://youtu.be/JwjnQqfFSGo?si=IOMTo44iGg27rHDp
My version from years back. Those can be made from sheetmetal parts quite easily. Cost was same as racing rotors from cast steel
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
The Following 2 Users Say Thank You to Vekke For This Useful Post:
blownb310 (09-28-2023), freebeard (09-28-2023)
Old 09-28-2023, 03:42 PM   #9 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
I'm assuming you are looking to reduce unspring and rotating weight? An easy way to do that would be to turn down the rotors to their minimum thickness. If you want to go further there is the option of drilling. The machined rotor material itself that contacts the pad and the area around the mounting holes for the wheel studs.
Bolt brakes are larger than necessary because they are shared with the Cruze Premier.
Old 10-01-2023, 10:27 AM   #10 (permalink)
Aluminum's melting point is too low, though typical brake pads also don't work at high temperature either. With cast iron rotors + high temp pads, performance is pretty acceptable.
