Old 01-23-2018, 10:03 PM   #71 (permalink)
Aero Deshi
ChazInMT's Avatar
MagMetalCivic - '04 Honda Civic Sedan EX
Last 3: 34.25 mpg (US)
Originally Posted by Angel And The Wolf View Post
Everything I've read says 15% is optimal for preventing slip stream separation You want the air to stay as close as possible to the skin to prevent turbulence
Sorry, gotta interject, First off, this is a flat cover, so the break from cab to flat cap top will really mess up any chance of keeping it anywhere near "Attached" at 15°. Secondly, the 15° thing is the Steepest you can be and not separate.....any thing Less....will maintain attached flow as well. Thirdly, The drag coefficient (Cd) between 5° and 15° (on an optimally shaped cap, will be within 5% of optimal.
So, As I've stated before, a 5-8° slope will yield the best results here, anything more will start to increase drag and cut into the usable space under cover.
The Following User Says Thank You to ChazInMT For This Useful Post:
slowmover (01-28-2018)
Old 01-24-2018, 03:04 AM   #72 (permalink)
A flat surface at any angle is suboptimal. Especially if it doesn't start at the maximum camber at the top.
Start flush and curve it to 22°. Respect the length/diameter for truncation. The section can be circular, square or squircular.
Old 01-24-2018, 12:14 PM   #73 (permalink)
Why 22 degrees? Why not the recommended 15 Degrees? Air speed does not decrease towards the rear.
Old 01-24-2018, 03:28 PM   #74 (permalink)
Why is there air? It starts and ends [relatively] motionless after the passage of the car. Velocity and pressure trade off with each other.
Where the 1930s Zeppelin designers used an airfoil section with a continuous curve from one end to the other, Mair was working on torpedoes, terminating a tubular body. 22° just falls out of the science.
I used 45° not 2x22° for simplicity's sake when I did these experiments:
Old 01-24-2018, 03:41 PM   #75 (permalink)
15 Degree Tail
I have drawn a study of the Prius with 15 degree tail section. The only area left vertical is the license plate. This could be made of a pipe frame and lightweight material stretched over it.
The Following User Says Thank You to Angel And The Wolf For This Useful Post:
freebeard (01-24-2018)
Old 01-24-2018, 05:30 PM   #76 (permalink)
Your design takes the 15° ball and runs with it.
Some points though
There is a positive pressure gradient the front and a negative one at the rear. So the front can be bluff. That shovel nose isn't important until ~250mph.
Your extended approach and departure angles work against you aerodynamically. The problem with the symmetrical side view is you have free air above the car and a plenum with one moving wall (whichever way you look at it) below. So you have interference drag at any reasonable ride height.
Theory has the vehicle as a half-body, with a 'ghost' vehicle inverted under it. Underbody flow is minimized and managed with tunnels and difussers.
I would describe your rear end as a high-tailed stinger. Here's an example from Breers in the 1930s:
I compared the high boat tail with a Tropfenwagen style here:
The one on the left uses a Coanda nozzle in the truncation because the Beetle has a supply of pumped engine cooling air ducted to exactly the right spot.
Flat taillights would loose maybe 0.005Cd. and maybe 12-15" in length.
Old 01-24-2018, 10:34 PM   #77 (permalink)
I can forget the front nose piece. Most drag savings is gained at the rear. I can't leave the lower angle of the tailpiece at 0 Degrees. It would drag on driveways I could raise the tail floor up, and make it 0 Degrees, but I don't know what that would accomplish. I guess I'll just have to build the boat tail, and test it on a two way run, after setting a reference trip without it.
aerohead (01-27-2018)
Old 01-25-2018, 02:31 AM   #78 (permalink)
That's the dilemma with a full boat tail. One solution is BamZipPow's Dark Aero single-wheeled trailer.
Another is a fenced diffuser to mangle the underbody flow, making little vortexes out of big ones.
Old 01-25-2018, 03:09 AM   #79 (permalink)
I do have another design, a one wheeled tapered trailer:
Old 01-25-2018, 05:03 AM   #80 (permalink)
There ya go.
A ball-and-socket connection and everything.
