Old 11-24-2010, 03:28 AM   #11 (permalink)
If not mounted vertically it can trap air, which will blow the element.
Its also about half as efficient if its like mine because there is a ball bearing valve inside that is a check valve the kind of helps it push water...
Different styles may be different though...
Dave
If it has a motor its worth playing with.......
Old 12-03-2010, 11:37 AM   #12 (permalink)
Does everyone have a timer to turn the block heater on sometime before your daily commute, or do you just have it plugged in all the time? I think mine is a 600 watt, and it just seems like a waste to have it plugged in all the time.
Old 12-09-2010, 01:53 PM   #13 (permalink)
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
Good stuff Brucey. Another option for a low point to siphon from would be the coolant drain if you have one on your block. That's what I used on my Prius. In fact the nipple they supplied with my heater was threaded to fit the drain union boss.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
Old 12-09-2010, 02:34 PM   #14 (permalink)
A madman
brucey's Avatar
Pequod - '17 Subaru Outback
90 day: 22.79 mpg (US)
Send a message via AIM to brucey
I'm considering redoing it at some point next spring with it installed properly. I will try and find a way to mount it vertically and tie it in with the heater core line as per instructions. Not that it isn't currently working well, but not following instructions scare me when my engines cooling system is being tinkered with. :P Currently it's simply inline with everything else.
And I plug mine in about 1.5 ~ 2 hours before I plan to leave, if I remember. I wish I could plan all my trips, but I just can't always do that. I've really come to appreciate it, not having to scrape the windshield and having heat. Even if the mileage is a wash by having to pay for the electricity, I still think something like this is worth it just for the other benefits.
Old 12-09-2010, 10:25 PM   #15 (permalink)
puddleglum's Avatar
Rondo - '07 Kia Rondo EX
Last 3: 20.47 mpg (US)
Tinkertoy2 - '00 Toyota Echo base
Last 3: 46.03 mpg (US)
Timers are a good idea and they are not very expensive.
Almost all my driving is done 1-5 miles at a time.
Best short trip: 2.4 l/100 km, 3.9 km
Civic Block Heater Install TomO DIY / How-to 42 04-04-2012 08:24 PM
One block heater or two? Piwoslaw EcoModding Central 15 08-14-2010 01:10 AM
block heater questions. phord EcoModding Central 3 01-15-2010 11:18 AM
Geo Metro Block Heater How-to bbjsw10 DIY / How-to 75 12-31-2009 12:34 AM
1.5 L Toyota block heater bwilson4web Hybrids 11 12-24-2009 01:30 PM
