Old 11-15-2013, 07:31 AM   #11 (permalink)
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
You could just unplug the injector to get a feel.
- Tony
Old 11-15-2013, 07:51 AM   #12 (permalink)
Basjoos Wannabe
ShadeTreeMech's Avatar
The Van - '97 Mercury Villager gs
90 day: 19.8 mpg (US)
Lyle the Kindly Viking - '99 Volvo V70
90 day: 25.82 mpg (US)
So you are running the cylinder without air going in or out? That would be like adding a shock absorber to the crank. And you will lose more than 25% of your power because the other 3 cylinders will be pushing this unused cylinder around. You'd be better off removing the piston completely rather than leaving it as is. And the oil burning issue will not go away. There is something leaking oil, and it was going into a cylinder and being burned off. If it is leaking into the burnt cylinder, that could be a major problem...
Have you ever heard an old Harley engine and seen it shake? They are designed as a 3 cylinder engine with one cylinder removed. There is indeed a reason old Harleys leave oil everywhere.
RIP Maxima 1997-2012
Originally Posted by jamesqf View Post
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
Old 11-15-2013, 10:21 AM   #13 (permalink)
Master Ecomadman
arcosine's Avatar
Team Saturn
Your logic is just plain wrong. The old Harleys leaked oil because that's how the chain was oiled. Air compressed in a cylinder is not a shock, but a spring. The honda is an old beater, just do it.
- Tony
Old 11-15-2013, 01:20 PM   #14 (permalink)
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 42.77 mpg (US)
This.
And a missing piston will create a horrendous unbalance.
Old 11-15-2013, 01:21 PM   #15 (permalink)
Yes, try it, and tell us how it goes.
Old 11-17-2013, 07:02 AM   #16 (permalink)
Exceptional Member
YukonCornelius's Avatar
Crapolier - '98 Chevrolet Cavalier base
90 day: 34.81 mpg (US)
05 CTS-V - '05 cadillac cts-v
90 day: 33.01 mpg (US)
95 Accord - '95 Honda Accord
90 day: 38.06 mpg (US)
11 CTS-V - '11 Cadillac CTS-V
I could not flip the rocker arms to accomplish my goal so the head is coming off. I will post pics. I believe there will be an incredible amount of deposits on some of the valves in cylinder 2 from all the oil burning. On any other car I would just replace the motor. They are cheap and easy to swap out. But doing that would defeat the purpose of this car. I've kept it so long to see how far it can go. Most of the car is original.
Love the new avatar. A little ball joint play there?
Yes, and right after a state inspection where I asked them to check the front end closely (because of the mileage).
Originally Posted by euromodder View Post
Crankcase pressure is not going to be 100 psi, is it ?
PS :
VW regard 1L / 1.06 quart per 2000 km (1242 mls) as normal ... on a 1L engine !
I don't have 100 psi after this valve issue, more like 0. Also, that immediate 1000 miles to a quart began 150,000 miles ago. The car is up to burning a quart every 400 miles or so. I almost need to leave a quart with a pin hole hooked up to it like an I.V.
I lost the cylinder while driving. Over the years I've driven about 30 miles with it missing a cylinder for various reasons, I could live with it. It idles and runs pretty well on 3.
Air would go into the cylinder past the bad valve and out past the open exhaust valves.
Normally you would be correct about loosing over 25% of my power. That cylinder doesn't make power equal to the others so my total loss would be less than normal. What that number is would require some dyno testing.
There is no chance I developed a oil leak at the same time and into the same cylinder as the deep gouge caused by the bad spark plug dropping a piece into the engine. I've had this head off before, I've seen the damage. I have to pull the spark plug out of that cylinder every other oil change and put it on a wire wheel to remove the giant hunk of rock hard deposit that has formed. The other 3 plugs always look normal. I'm sure each cylinder is burning some oil but the majority gets burnt in 1 place.
Don't know why it says 00, it's a 95
374,000 miles and tired.
Old 11-17-2013, 08:05 AM   #17 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 50.48 mpg (US)
Yipes.
Originally Posted by Lbar View Post
Avatar changed to my favorite picture of the car in question.
Nobody would loan you a pickle fork?
Old 11-17-2013, 08:09 AM   #18 (permalink)
Master Novice
elhigh's Avatar
Air compressed is indeed a spring...but this cylinder with the bad valve is more like a shock. It'll absorb a lot of energy as the compressed air leaks through the gap.
If you feel okay driving it, that's your call. But it'll be a complete pig to drive. My Expo crapped a valve and it went from halfway lively microvan to dispassionate shambling zombie, complete with fog effects.
Old 11-19-2013, 08:32 PM   #19 (permalink)
Seems like turning it into a 3-banger while keeping the dead cylinder still there wouldn't be really so effective. I'd also be quite concerned about the oil pressure. If you could remove the rod and piston from the dead cylinder and close the hole from the crankcase to the cylinder in a way that wouldn't have any clearance issue with the crankshaft it might work as you may be wanting to. If you do so, should also disable the valves from the dead cylinder.
Old 11-21-2013, 02:20 AM   #20 (permalink)
Exceptional Member
I took the head off today, fun fun. Pics on next post.
The Following User Says Thank You to YukonCornelius For This Useful Post:
pgfpro (11-21-2013)
