Old 07-03-2008, 02:46 PM   #11 (permalink)
Less IS more!
Clementine - '82 Freeway HMV Deluxe
Ooops...almost forgot. These are the numbers for the XFi cam-a-lot:
XFI Model
Standard camshaft lobe height is 39.628 to 39.788 mm
(1.5602 to 1.5665 inches).
Wear limit 39.528 (1.5562 inches).
Less IS more !
Old 02-25-2011, 11:18 PM   #12 (permalink)
GGGGeopet
Where can I get some final drive gears to put in my stock geo tranny? Need the 3.4s off the 4 cyl.
brotheroftheson
Old 02-26-2011, 07:09 AM   #13 (permalink)
Less IS more!
Final drive
This gentleman has it:
Martin Lachapelle
1634 John F. Kennedy
Lasalle
five one four three six six nine seven zero nine
Less IS more !
Old 02-26-2011, 08:39 AM   #14 (permalink)
n00b.... sortof..
d0sitmatr's Avatar
silver fire - '03 Mazda Protege5
90 day: 32.52 mpg (US)
my first car !
thing was a beast, had a 4 spd manual trans powered by a 305 (I think) w/ 4 barrel carb.
I smoked many a high priced sports car in that thing, nothing like watching someone driving a porsche almost drop their jaw to the floor
... also went through quite a lot of tires.
~Mike
Old 07-05-2011, 11:44 PM   #15 (permalink)
nuc
Hi Frederick,
After a lot of searching I was happy to see that someone had located a source of the 3.523 gears w/out having to scour all the junkyards looking for a 1.3l Swift
Thanks for the effort!!
As I am in the states, would you have an email for Martin? Or possibly the area code?
Thanks
Also, what is he charging for the gearset?
Thanks again
Old 01-26-2012, 09:56 AM   #16 (permalink)
The Saudi Terminator
Saudi Terminator - '93 Geo Metro Base
90 day: 66.59 mpg (US)
What were your new mpg numbers Frederick? How much did the XFI improve? I have heard you can expect around a 2-3 mpg increase by doing the XFI cam swap.... Just researching everyones experiences when they did the swap....
Old 01-26-2012, 11:00 AM   #17 (permalink)
Less IS more!
XFi cam
Hi there.
Not only did I install an XFi cam but I also replaced my final drive gear set with one from a 4 cyl.
I tell the truth when I say that there is almost no change in performance, although passing is still a chore.
My driving habits have been changed to a more serene conduct.
All this said, and it's winter, my conservative estimate is that I'm doing 8-9 more miles per gallon. It's quite ardouous to translate in mpg but I do 550 km per tankfull. Summertime, a little less in winter.
Even though I have heard so many different opinions about burning super in our sewing machine cars, even though the price of said fuel is more expensive, when everything is calculated I get 30 FREE km when using it.
I like my car so much that I treated it to a very thorough new paint job, worth many times the value of the car. Espresso Nero lives on...and on....and on.
DO THE SWAP! Do BOTH swaps! And be happy. Drive consevatively and you will stretch the car, your life and your dollars.
Less IS more !
The Following User Says Thank You to Frederick For This Useful Post:
Georgboy (01-26-2012)
Old 01-26-2012, 11:29 AM   #18 (permalink)
Thanks!! Sounds like a good idea I have the regrind at the house and have already lengthened my gears by installing 135-80-15 tires at 45 psi.. Last tank was 66.6 mpg on stock cam 9 degrees adv., and Hypermiling techniques ...
Old 01-26-2012, 11:38 AM   #19 (permalink)
Less IS more!
Wow!!!!
Less IS more !
Old 01-26-2012, 12:32 PM   #20 (permalink)
Hypermiling is addictive haha!! I want to get some solid numbers on the setup I have now with the new tires and start from there. I am hoping for around 8 mpg with the cam, but I wouldn't happy with 4 I guess... Next after the cam I will look into a front air dam to see about improving farther... Anyone had any luck with a air dam mod?
Metro taller transmission swap thread: +5% efficiency gain (taller final drive) MetroMPG EcoModding Central 36 02-11-2015 11:08 AM
Blackfly XFi? Geo Metro economy cam shaft swap! Update: swap completed MetroMPG EcoModding Central 31 11-09-2014 05:28 PM
Geo Metro XFI Convertible Project Finished Coyote X EcoModding Central 227 11-14-2009 10:31 PM
Final gear drives for GEO METRO, Swift...Firefly Frederick For Sale 7 09-09-2009 12:03 AM
How to tell an XFi from a garden variety Metro MetroMPG General Efficiency Discussion 6 07-12-2008 10:48 PM
