02-10-2010, 07:19 AM
EcoModding Alien Observer
Any testing on mpg effects of using various gear oils?
* regular dino gear oil
* full synthetic (same viscosity)
* synth ATF with added Lubegard or Militec or moly additive
Carry on humans...we are extremely proud of you. ..................
Forty-six percent of Americans believe in the creationist view that God created humans in their present form at one time within the last 10,000 years. GALLUP POLL
02-10-2010, 06:39 PM
epic stock master
i saw a 3mpg increase at 72mph on my first tank. (over 11% increase)..
with the blizzard, i can reliably get another reading this week.
maybe next week or so.
full synthetic engine oil and full syth trans fluid, same velocity for my accord
02-10-2010, 07:30 PM
ECO-Evolution
You can start here. Some good stuff in there.
"Judge a person by their questions rather than their answers."
02-10-2010, 10:09 PM
Moderate your Moderation.
Pasta - '96 Volkswagen Passat TDi 90 day: 45.22 mpg (US)
In theory, you shouldn't see a gain from using synth over conventional in the same viscosity.
02-10-2010, 10:12 PM
epic stock master
i should double check the oil that was put in my engine.. the oil change place looked-up my car to choose the syth oil
02-11-2010, 06:56 AM
As far as I know...viscosity is more controlled with synth vs dino gear oil...meaning that when cold synth is thinner. One person claimed that after changing to synth gear oil...same weight...he could coast further with synth oil.
I had an '86 Escort that used ATF in a manual transaxle....thinking that using synth ATF with a good additive might work...but might be risky too.
02-11-2010, 07:31 AM
Good link!
02-11-2010, 01:02 PM
Ford recommends the use of Mercon-based fluid in almost all their manual transmissions, with few exceptions, that I'm aware of. You're correct thinking that synthetic, as a rule, is more stable. I'm not sure this applies in a transmission as much as in an engine, but I can't really support that thought.
Using synth ATF that applies to the same specs as your original trans fluid will be fine on it's own. You can go to Ford dealer and get a 4oz can of friction modifier, but it's probably not necessary for the older trans?
02-11-2010, 03:58 PM
#9 (permalink)
If you search bwilson4web's posts, you will also find documented testing showing the effect of changing gear oil type/viscosity in his gen. 1 Prius.
02-11-2010, 04:05 PM
#10 (permalink)
The viscosity stability of synthetic gear oils should return better efficiency in cold conditions. It's an issue for transmissions/differentials, since they don't benefit as much from the heat of combustion as engine oil does.
I can find dozens of links that claim to support this notion.... but can I find one on short notice that appears to have some science behind it? Nope!
Anyone?
