Old 06-24-2021, 12:52 PM   #151 (permalink)
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
Transparent aluminum.
Aluminum oxide would be a suitable alternative to glass actually and potentially stronger and more scratch resistant.
Old 06-24-2021, 01:51 PM   #152 (permalink)
Thalmaturge
CHONK - '18 Honda Clarity
I think making the windows out of giant sapphires might make the car slightly more expensive though
Old 06-24-2021, 03:25 PM   #153 (permalink)
...potentially stronger and more scratch resistant.
If I understand correctly, the Cybertruck glass is essentially transparent aluminum. We saw how that went.
It's sintered from a powder so (maybe) no sheets you can cut to size. Same as Safety glass?
Old 06-24-2021, 09:27 PM   #154 (permalink)
Plexiglass is a trademarked name of Dupont.
Didn't it become some sort of genericized trademark?
I believe you are describing acrylic sheet which comes in many subsets of density, toughness and flexibility.
You're right. I was refering to acrylic sheets. And some clearly have a poor optical performance which renders them less desirable than actual glass, while others are OK for that matter.
Lexan is another trademarked polycarbonate with many coatings applied to alleviate the inherent faults of the base product for a specific purpose.
I remember Lexan sheets being used more often on racing cars for weight savings.
Home building places stock a common house window glazing grade that tends to not see rock impacts
Common house window glazing in my country is not so easily found on such grade.
