Old 12-20-2024, 11:29 AM   #21 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Originally Posted by CigaR007 View Post
I have been observing the coolant temperature for the past few days. With the shutters SHUT, at constant speeds, as soon as the coolant temp reaches 95-96C, it stabilizes and gradually drops to 91C. The cycle repeats every 5 minutes or so.
This leads me to consider that the Radiator fan is running on low speed and the trigger temp seems to be around 96C.
This is a good example why knowing when the radiator fan is ON is useful.
That does seem correct. My turbodiesel's fan turns on at 98C and off when the temp drops below 90 or 91C.
The fan goes into 2nd stage, or high, if the coolant temp rises above 104C, iirc.
Ecodriving goal: Drive so efficiently that the engine does not waste enough energy to heat up to 96C.
The Following User Says Thank You to Piwoslaw For This Useful Post:
CigaR007 (12-20-2024)
Old 12-20-2024, 11:46 AM   #22 (permalink)
CigaR007's Avatar
GreenTurtle (Retired) - '01 Toyota Echo Sedan
90 day: 44.85 mpg (US)
Zulu - '14 Honda CR-Z
90 day: 49.05 mpg (US)
Question then becomes : which of the following has a higher penalty ? The aero drag with shutters half-open or the increased electrical load to power the Rad Fan at low speed ?
Considering the vehicle has no alternator, the engine load might not change much given that the Hybrid DC-DC converter ultimately provides the power through the small 12V battery...
Soon enough, with colder temperatures, the coolant will probably not reach 95-96C.
Old 12-22-2024, 10:31 AM   #23 (permalink)
CigaR007's Avatar
Considering the Electric Fan turns ON (low speed) earlier than expected (96C), I modified the logic circuit to accommodate that.
I don't know how much power the radiator fan consumes on low speed.
I think the fan circuit is on a 30A fuse.
So theoretical electrical load would be 12.6V x 30A = 378 Watts on full speed. Not sure, but Low speed could be half that, so around 190 Watts.
I would assume the aero drag would be higher than 190 Watts with shutters 50 % open.
Keeping shutters SHUT and allowing the fan to run on low speed might be more efficient, but the trade-off would be increased wear and tear on the fan motor. Which is why I considered an approach that allows a more gradual cooling.
Trigger points :
Below 90C : shutters SHUT
Above 90C : shutters open @ 25 %
Above 93C : shutters open @ 50 %
Above 96C : shutters open @ 100 %
Fans ON : shutters open @ 100 %
Old 12-28-2024, 05:33 PM   #24 (permalink)
[QUOTE=CigaR007;697639]
Trigger points :
/QUOTE]
Cant argue with that er... logic.
Any plans to expand this to be able to control the temperatures at wich the fan/s come on at their various speeds?
Control other stuff like alternator on/off, aircon pump off during acceleration etc?
Old 12-29-2024, 04:53 PM   #25 (permalink)
CigaR007's Avatar
You mean to change the actual trigger temperature commanded by the ECU/PCM to trigger the Fan relays ?
Highly unlikely given the complexity. There is no alternator, just a DC-DC converter that powers the accessories and maintains the 12V battery charged. It's probably pretty efficient as-is (>90%).
The Following User Says Thank You to CigaR007 For This Useful Post:
Logic (12-30-2024)
Old 12-29-2024, 04:59 PM   #26 (permalink)
CigaR007's Avatar
Been working on a PCB for the logic controller. I am using an open-source software called KiCAD to build the electronic circuit. Once the circuit is created, there is an option to create a PCB. Pictures below show the rendered PCB with the components. Looks promising when the design will be finalized after the testing phase.
ID:	35421   Click image for larger version
Old 12-30-2024, 05:00 AM   #27 (permalink)
Possibility? But not necessarily.
I'm out of my depth here and just wondering if your system is expandable to control more of cars cooling system/s and if you are thinking in that direction?
Ah; a hybrid.
(Is the 12v battery also Lithium?)
Old 01-03-2025, 06:47 PM   #28 (permalink)
CigaR007's Avatar
I would have to study the control/trigger wiring diagrams a bit more in-depth before attempting to modify the fans speeds triggers. At this moment, it is not being considered in the design.
Ah; a hybrid.
Regular lead-acid.
Logic (01-04-2025)
Old 01-03-2025, 06:51 PM   #29 (permalink)
CigaR007's Avatar
I combined my logic circuit with the GUI. As you can see in the video, I simulate different logical states that represent the shutters position (Green LED =SHUT, BLUE LED= 50% and Red LED = OPEN) and it is reflected on the GUI.
Old 01-15-2025, 09:37 AM   #30 (permalink)
(Controller Area Network (CAN) bus is a communication protocol that allows devices to exchange messages without a central computer. It's used in vehicles)
A lot of how to CAN bus stuff here.
I thought you might find it interesting.
CigaR007 (01-16-2025)
