Old 03-28-2016, 07:12 PM   #1 (permalink)
Metro - '98 Chevy Metro
Automated alternator delete
I ordered a shifter knob from Daox, very excited for that, and got to thinking, what should I do with the toggle switch. Daox recommended I use if for an alternator delete.
Unfortunately, I drive so much highway, and my stops would not be enough to keep the battery charged. But, I had an idea.
Tap into the power for the fuel injectors. When the deceleration fuel cut off activates, power stop, it also could activate the relay for the alternator delete.
Old 03-28-2016, 11:48 PM   #2 (permalink)
EcoModding flying lizard
Daschicken's Avatar
Cibbie - '88 Honda CBR 250R
Motorcycle
90 day: 48.49 mpg (US)
Rarity - '06 Honda Accord EX V6
90 day: 29.88 mpg (US)
Baby viff - '86 Honda VFR 400R
Motorcycle
90 day: 42.15 mpg (US)
Latios - '08 Suzuki SV650SF
Motorcycle
90 day: 64.56 mpg (US)
Mazda 3 - '14 Mazda 3 i Sport
90 day: 43.25 mpg (US)
Are you suggesting that you turn off the alternator when dfco'ing? I would think that would be the best time to have it ON, since that is the only form of 'regenerative braking' a gas car can do.
-Kaze o tatakaimasen-
Best trip in V6: 52.0
Best tank in V6: 46.0
Best tank in Mazda: 49.9
Best tank in CBR: 61.3
Best tank in SV: 83.9
You can lead a fashion-conscious horse to unusual-looking water...
Old 03-28-2016, 11:53 PM   #3 (permalink)
I am suggesting that when the current stops to the injectors, it also stops to a relay that would turn off the alternator delete.
Old 03-29-2016, 12:06 AM   #4 (permalink)
Or you could just use the switch. YOU can account for daytime and projected usage pattern for the trip which if automated may not.
Old 03-29-2016, 12:23 AM   #5 (permalink)
BeginnerModder
So I saw your post title and thought, "Damn, that's a great idea", then I opened up the thread and it went a totally different direction than I was thinking.
Why not just have a Raspberry Pi or arduino or other micro-controller/micro-computer monitor a few inputs (Battery voltage, draw, throttle position) and have it throw a relay to cut your alternator in and out when it meets the prescribed variables?
Old 03-29-2016, 12:37 AM   #6 (permalink)
Wouldn't the goal be to arrive home- or at a place to charge up- needing a wall-power charge? Otherwise the existing voltage regulator more or less does the job, unless you have a car with a "smart" regulator which does a bit of regen charging.
Old 03-30-2016, 05:51 AM   #7 (permalink)
I think better than an alternator "delete" would be an alternator cutout switch attached to the throttle that activates when you press the pedal past some point. The higher the load, the less efficiency you gain from adding load. If the engine happens to be idling or DFCOing, you might as well charge the battery. This is how the new BMWs and Mazdas work. You probably want a manual switch anyways to charge the battery if you haven't charged it in a while and don't want to be stranded.
Old 03-30-2016, 10:13 AM   #8 (permalink)
I like the idea of using an arduino, but then I asked myself, when else do I want to charge the battery? Almost never. Possibly a manual override would be nice, but the DFCO thing handles almost all the regen situations you would want.
Old 03-31-2016, 04:24 AM   #9 (permalink)
I think a switch that triggers on throttle-off is the best way to do it, that way you don't need to detect if the injectors are off, just screw a 1 dollar switch near the gas pedal and it's good to go. Foot off the throttle = either DFCO, slowing down in gear at low speed, or idle, which are all good times to charge.
Old 02-03-2018, 06:18 PM   #10 (permalink)
teoman's Avatar
A3 - '12 Audi A3
How does one determine if they already have a smart alternator?
Monitor the voltage from the cigarette lighter?
