Old 07-22-2011, 07:08 PM   #21 (permalink)
graydonengineering's Avatar
Frontier 2wd 2.4L 5 speed - '98 Nissan Frontier XE
90 day: 27.87 mpg (US)
Originally Posted by khafra View Post
I, for one, like the cheap, reliable, automated 80% solution that errs on the side of safety. After watching my temps for a while in the Florida summer I don't know if I can afford to block my grill even partially at highway speeds; but I'd still like to see the build process and performance, when you get that youtube video up.
If your cooling system can't keep up un-modified, you may need to take a closer look at your cooling system. If your coolant is full and properly balanced and your thermostat is working, the radiator is most likely coated with minerals inside. It is a little know fact that only distilled water should go in a radiator to prevent efficiency killing mineral deposits..
-Miles
Best 15-mile commute city/highway mix: 37.7 mpg
Best tank so far: 31 mpg
Old 07-22-2011, 07:17 PM   #22 (permalink)
...beats walking...
...the infamous calcium "white death" deposits (got my 1984 Honda!).
Old 07-23-2011, 12:00 AM   #23 (permalink)
The shutter has been installed and working as intended (shutting around 50 mph) for about 150 miles now so I figured it is time to finalize the installation and put the grill back on. I'm sure having it off is not helping my drag one bit.
Bench test of what will be my indicator light housing for the shutter indicator led's. A buddy of mine has a 3D printer so I through an STL file together and did the sanding and painting to make the grooved nylon smooth. Next 3d print project, a custom gauge mount pod for my Scangauge!
-Miles
Old 07-23-2011, 02:25 AM   #24 (permalink)
The intro:
In the drivers seat test
-Miles
The Following 2 Users Say Thank You to graydonengineering For This Useful Post:
CigaR007 (07-24-2011), slowmover (07-24-2011)
