Old 02-27-2013, 04:54 PM   #51 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
If they are that cheap I will ask an offer, thanks .
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
Old 02-28-2013, 04:55 AM   #52 (permalink)
HypermilerAX's Avatar
AX - '95 Citröen AX
307 - '04 Peugeot 307 SW
FYI, the flowmeters are based on a hall effect sensor and need a pull-up resistor between signal and 12V to work (1,6 to 2,2 kohm) which are not included.
Citroën AX 1.5 D 430.000 km
Peugeot 307 SW 2.0 HDI 136 195.000 km
Old 02-28-2013, 05:06 AM   #53 (permalink)
la_voiture_de_courses - '03 Renault Megane Estate
OldContinents
90 day: 44.34 mpg (US)
xiao lan - '01 Audi A2
90 day: 38.88 mpg (US)
Brit iron - '92 Mini Mini
90 day: 45.5 mpg (US)
Prius - '09 Toyota PRIUS Lounge
90 day: 47.37 mpg (US)
Beemer - '06 BMW F800 ST
90 day: 53.06 mpg (US)
I believe you are building a great scan gauge alternative for older cars.
I don't know if there is a market but there is definitively material for a new thread (and if not, this one might be jacked up)
Old 02-28-2013, 06:22 AM   #54 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
Originally Posted by HypermilerAX View Post
The flowmeters are rather cheap (20€ each) but the unit was expensive : 150€.
You can use Arduino to measure fuel flow with flow meters. Some MPGuino code changes would be necessary, but it's doable. There is a thread related to the issue http://ecomodder.com/forum/showthrea...sel-16711.html
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
Old 02-28-2013, 10:55 AM   #55 (permalink)
AX - '95 Citröen AX
Thanks, I will think about it.
The next step would be to have the fuel consumption in l/100 km. For that, I already have an alternative signal (self-made, my speedo is mechanical) for speed. Now, I would need something that can handle the different types of signals in input, do the calculation ((flow2-flow1)/distance) and display it.
Is Arduino capable of that and how complex would that be ?
Old 03-01-2013, 06:49 AM   #56 (permalink)
AndrzejM's Avatar
Of course it is! You just need to do some major changes to the code if you want to have an instant FE reading. If you just need an average it's fairy simple because all you need to do is counting pulses from both flow meters and do some match to have it displayed as l/100km, mpg, km/l etc.
If you want to have instant reading you have count time between pulses on both flow meters.
Old 03-04-2013, 09:15 AM   #57 (permalink)
AX - '95 Citröen AX
I was just caught in a traffic jam (very slow but also very short). 300 m stop&go in first gear at about 3 km/h average, I consumed 48,1 mL in 220 m = 21,7 l/100 km
Old 03-04-2013, 03:29 PM   #58 (permalink)
OldContinents
Yeah, we all try to avoid that but that's good to know how much it does cost.
Old 03-25-2013, 04:51 PM   #59 (permalink)
Tango - '15 Fiat Panda Trekka
Excellent work!
I'm running a stock AX 1.5 on 50-75% veg oil at the moment and getting 75 mpg (imp) or 3.8 l/100km so I have some way to go. I have an air leak into the fuel line to track down at the moment but once that's sorted i'm back on the MPG case. Weight to loose, gaps to seal and an alternator to loose.
Old 03-25-2013, 05:04 PM   #60 (permalink)
HyperMileQC's Avatar
Trollinsight (Retired) - '00 Honda Insight
Gen-1 Insights
90 day: 68.06 mpg (US)
Redsight - '01 Honda Insight
Gen-1 Insights
Carole - '05 Toyota Corolla Xrs
Brise-Fer - '05 Toyota Echo
Send a message via MSN to HyperMileQC
You mean 38 KPL?
Trollinsight Modding Thread
2000 Honda Insight MT Silverstone Metallic #95 (CAN) 131K mi. 81.7 Lmpg
Best Tank : 100.06 MPG (US) | 120.2 MPG (Imp) | 2.35 L/100Km | 42.54 Km/L
Best commute : 130.8 MPG (US) | 157.1 MPG (Imp) | 1.8 L/100Km | 54.84 Km/L
Best Trip : 111.8 MPG (US) | 134.3 MPG (Imp) | 2.1 L/100Km | 47.53 Km/L
