Old 05-15-2012, 05:12 PM   #11 (permalink)
0.60
Originally Posted by skyking View Post
so now I'm down to .60 eh?
I've deleted my comment about the Me-109.It's a cinch that I'm attempting to vibrate way above my assigned frequency whenever I get into aeronautical stuff.
Anyway,I rehashed the numbers:
At sea-level,the 1,200-hp engine,working through a variable-pitch prop of 0.78 efficiency delivers 920-lbs of thrust,plus 140-lbs from the exhaust,for a total 1060-lbs.
At terminal velocity,drag equals thrust.
At sea-level the plane will max out at 292 mph.
The frontal projected area of the entire plane is about 31.112 sq-ft.
Setting F= 1060-lbs,and using standard density,solving for the frontal-area based drag coefficient yields Cd 0.156 (1984 Ford Probe-IV ).
While the 0.60 Dodge is a bit higher,it looks like it is possible to match the Cd of the Messerschmitt.Of course,it will no longer ;look' like a 'Dodge' but it will have the low Cd.
The piece de resistance would be matching a 1935 Douglas DC-3,at Cd 0.12!
Last edited by aerohead; 05-16-2012 at 05:37 PM.. Reason: comment deletion and correction
Old 05-15-2012, 05:53 PM   #12 (permalink)
darcane's Avatar
Wow, you did good. Interested in see what sort of results you see.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
Old 05-15-2012, 06:45 PM   #13 (permalink)
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
Sounds nasty 'til you consider that a Messerschmitt Me-109 "G" has a higher Cd.
I was just joshing ya, the only source I can find is 0.44 for my truck. I think it is more like .46 with the bed lower like I have it.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
Old 05-15-2012, 08:06 PM   #14 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
Nice work. Do you have any photos of the truck on the ground with that- ie, does it show at all?
Old 05-15-2012, 09:43 PM   #15 (permalink)
skyking's Avatar
Here are the money shots, down on the suspension at a normal ride height.
I put the pan inside the arms of the A-frames themselves.
The edge of the plastic shows here, and especially where I could not get a screw in there because of the lift arms. I plan on using an aluminum carpet edge to clamp the plastic to the aluminum running board, with countersunk screws. I will paint the final edges with a rubberized undercoat.
The rear axle is in line or above the pan, except for the spring clamp bolts and shock mounts. I really did not want to squeeze the air. It starts out at ~10.5" ground clearance up front, maybe 10" under the crossmember, then tapers up to about 13" at the axle. I could lower the front section to match, but it would be effectively lower than the lowest front suspension component if I did. The crossmember is only about 25" wide in the low area.
It is down about 5" below the original bumper, but that will all get covered by the new bumper/spoiler. I ran with this much radiator cover over the pass the other day, and no fan.
2003 TDI Beetle
2002 TDI Beetle
The Following 4 Users Say Thank You to skyking For This Useful Post:
BamZipPow (05-16-2012), darcane (05-16-2012), Diesel_Dave (05-25-2012), Sven7 (05-16-2012)
Old 05-16-2012, 04:54 AM   #16 (permalink)
clank - '99 jeep tj sport
90 day: 17.32 mpg (US)
would your box/what you tow allow you to put a flip kit on it(move the axle to the other side of the spring).
Old 05-16-2012, 08:14 AM   #17 (permalink)
90 day: 19.36 mpg (US)
One heckuva change. We can "forget" both how long and how deep is the undercarriage of a full-sized pickup truck in comparison to the short and shallow area of bellypan coverage on an eco-commuter.
Thus I doubt it would pass muster by the Border Patrol at their checkpoints . . an irony of efficiency.
The Following User Says Thank You to slowmover For This Useful Post:
skyking (05-16-2012)
Old 05-16-2012, 08:35 AM   #18 (permalink)
skyking's Avatar
that would be impossible. The axle is only a few inches from the frame when loaded down now.
2003 TDI Beetle
2002 TDI Beetle
Old 05-16-2012, 08:36 AM   #19 (permalink)
skyking's Avatar
They've never been shy about taking things apart
2003 TDI Beetle
2002 TDI Beetle
Old 05-16-2012, 03:00 PM   #20 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
Looks excellent SkyKing. I can't see much scope for improvement, but i'm sure the road will find something.
Wanna do a Ford?
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
The Following User Says Thank You to Big Dave For This Useful Post:
skyking (05-25-2012)
