Old 05-14-2008, 02:08 PM   #21 (permalink)
Blue - '77 Chevy P/U
Originally Posted by jim-frank View Post
There are some nice tutorials at the WISIL site, including one on vacuum bagging at http://www.wisil.recumbents.com/mars...FS00intro.html
cool
Old 05-19-2008, 04:32 PM   #22 (permalink)
The work continues
The belly pan is continued with lexan from the rear axle to the back bumper.
I want to do some work around the wheel wells. Likely will use some spray foam to tidy up the openings.
On the now much shorter list are front wheel diffusers, before and behind,
Smaller rear wheel diffusers,
Rear wheel skirts, and
Fresh fill of Amzoil transmission fluid.
I also wand to do some work with vortex generators to smooth the air coming off the back of the car and coming off the rear view mirrors.
I can't wait to get a tank of gas through the car on a highway roadtrip.
Old 05-25-2008, 09:27 PM   #23 (permalink)
So I have a tank of gas through the car average 65 mph
got 41.39 miles per CDN Gallon. EPA is 36
I am satisfied. Was also running into a headwind.
Old 05-26-2008, 12:22 AM   #24 (permalink)
Old 05-27-2008, 02:33 PM   #25 (permalink)
Well I have the back side of the trip in.
Had the cruise set on 65 mph, 379.5 miles
Fuel Consumption
Litres per 100 Km .......... 6.66
Miles per Imperial Gallon .. 42.42
Miles per US Gallon ........ 35.32
Kilometres per Litre ....... 15.03
17.8% over the Highway EPA at 65mpg. I continue to be a happy puppy ;-)
Old 05-27-2008, 03:18 PM   #26 (permalink)
ttoyoda's Avatar
Do you plan to measure your catalitic convertor temperature? If the temperature gets high enough the ceramic honeycomb inside will begin to erode. The erosion may partially block some of the honeycomb.
here is one of the possible part numbers for the matrix cat and front pipe from the factory:
174100D170
here is the price from 1st toyota parts $842.28
Though with the price of gas maybe your answer is "don't care".
Thats OK too.
The Following User Says Thank You to ttoyoda For This Useful Post:
Cd (06-12-2010)
Old 05-27-2008, 06:50 PM   #27 (permalink)
Belly Pan and Aero/Ecomodding
Thanks for your concern.
I think that there is enough air around it to keep it in the operating range.
Additionally no one ever, except under warranty replaces a cat with a Toyota stock cat. Not even a lottery winner.
MagnaFlow Catalytic Converter 94105 at $65.10 is the part all the enthusiasts use.
Old 05-28-2008, 11:05 AM   #28 (permalink)
ttoyoda's Avatar
Okay, I did not mean to be a wet blanket.
If you are willing to cut and weld the exhaust system, then an aftermarket cat is a better deal.
Reason I mentioned it was that I once was a passenger in a very old honda civic which had some water in the gas, and the car was misfiring and putting raw gas into the cat.
The car ran poorly, but it ran, and the driver just wanted to get it home. It was only when someone passed us to say we had orange hot and molten things falling from under the car that we found out that the cat casing was melting away and falling on the road. I would have never believed that was possible if I had not seen it myself. When we opened the hood the cat (it is right on the exhaust manifold in that car) was glowing very bright red. It was a sunny day in the winter, and you could see the cat just glowing very plainly.
So now I have a lot more (excessive?) caution about cats.
Old 05-30-2008, 08:23 PM   #29 (permalink)
Dramatic reduction in wind noise!!!
I have added Zig-Zag Vortex Generators aka a Turbulator on my side rear view mirrors.
Frankly I don’t feel or hear anything different and do not expect to find a measurable effect on the mpgs. I also do not see the potential for any large or measurable negative effects.
Then I added Zig-Zag Vortex Generators aka a Turbulator on the front A Pillars and there is a dramatic reduction in wind noise. There is still some left but it is dramatically reduced
Given that Toyota has used Vortex Generators on the Tacoma outside rear view mirrors and there is some excellent glider data for the Zig-Zag Vortrex Generators I thought that I would go for it and am much more than pleased at the results.
Old 05-30-2008, 08:32 PM   #30 (permalink)
where did you get that ???
Metro undertray / belly pan MetroMPG Aerodynamics 47 03-13-2014 05:13 PM
Vortex generators - where's the solid data for hatchback/van benefits? MetroMPG Aerodynamics 70 03-14-2012 12:25 PM
Honda's OEM vortex generators ... on the Ridgeline pickup mirrors MetroMPG Aerodynamics 21 12-06-2008 01:09 PM
More than one Vortex too! Christopher Jordan Fossil Fuel Free 2 02-17-2008 07:57 PM
Plant Stand Vortex Generators? cfg83 Aerodynamics 7 02-14-2008 11:11 PM
