Old 01-16-2019, 09:26 PM   #1 (permalink)
IS - '92 BMW E36 318IS
90 day: 38.73 mpg (US)
90 - '95 Honda Civic EG4 VX
90 day: 43.44 mpg (US)
Benefits of undertray lip?
Hello, I have a doubt!
I watch several cars, how suvs with a undertray lip, behind the front fender.
And also Cámaro zl1 1LE has one.
Does it have the same properties as a normal front lip of the fender? Despite being behind?
I think that it will increase the lift, but Cámaro zl1 has one....
Sorry for my English!
The Following User Says Thank You to fastflyer For This Useful Post:
aerohead (01-19-2019)
Old 01-16-2019, 10:43 PM   #2 (permalink)
I can't be sure what you're pointing to.
With the Camaro it's not clear whether the [lower element/feature in question] is vertical or horizontal.
With the HR-V it appears to have a vertical air dam with a central notch, followed by two wheel spats.
A biplane splitter is a race car thing, air dams and spats are eco-things.
"We're deeply sorry." -- Pfizer
Old 01-17-2019, 08:30 AM   #3 (permalink)
Other:
Old 01-17-2019, 03:45 PM   #4 (permalink)
Alfa romeo 4c
Old 01-17-2019, 06:16 PM   #5 (permalink)
Does this graphic image help clarify your terminology?
S2000 Aerodynamics
https://robrobinette.com/S2000Aerodynamics.htm
Note how the high pressure (red) bubble sits on top of the splitter adding downforce. The underside of the splitter also generates low pressure (blue) and downforce but the splitter needs to be lower than about 3 inches to generate this low pressure area. Graphic by Hancha Group Consulting.
Less blue area with a splitter, blue is lift from what I can tell - it has a negative number.
There is also an explanation for "dive planes" in that link, just more down-force and more drag.
Chin Spoiler:
http://forums.pelicanparts.com/off-t...effective.html
Rear Spoiler Pick Up Truck
http://forums.pelicanparts.com/off-t...xperiment.html
Roof Wing
http://ecomodder.com/forum/showthrea...1-a-19525.html
aerohead (09-27-2019)
Old 01-17-2019, 06:35 PM   #6 (permalink)
Yep, but the air dams of I refer are behind the front of the bumper...
Old 01-17-2019, 07:31 PM   #7 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
Putting them further back is a concession to practicality, they won't scrape as much on driveways etc.
Old 01-18-2019, 11:11 AM   #8 (permalink)
Exactly, and the main point is - not much of a difference from the CFD images I posted.
Don't look for the small differences just yet fastflyer, look for the overall similarities to understand the concepts involved.
EDIT:
Another way to place value/importance to the forces on the chin spoiler with and without splitter relative to it's inboard or outbard distance from the center of vehicle gravity is to reflect upon "moment arms".
https://www.physics.uoguelph.ca/tuto...que.intro.html
Imagine pushing a door to open it. The force of your push (F) causes the door to rotate about its hinges (the pivot point, O). How hard you need to push depends on the distance you are from the hinges (r) (and several other things, but let's ignore them now). The closer you are to the hinges (i.e. the smaller r is), the harder it is to push. This is what happens when you try to push open a door on the wrong side. The torque you created on the door is smaller than it would have been had you pushed the correct side (away from its hinges).
I'm just saying that the further out from the center of gravity (C of G) the more the resultant effect.
That is to say, move the same force a little more inboard, and it will not have the same effect, it will be less.
To put your mind at ease, the chin spoiler and or splitter tucked further under the car is going to exert less force because of it's shorter moment arm.
Below is an example of using moment arms to maximize down-force on front and rear axles.
https://www.f1technical.net/forum/vi...16453&start=30
The idea location for down-force on a well balanced car would be at it's center of gravity, but the wing must be much larger because like the door and door hinge example there is a very short moment arm (so more force is needed to get the same net results - work done).
By studying these extreme examples of moment arms in practice you can put in context and properly evaluate the effects of tucking inboard a chin spoiler 6-inches or so.
Chin Spoiler:
Roof Wing
Old 01-19-2019, 12:36 PM   #9 (permalink)
lip
General Motors has said that everything they've done on the Camaro is for high speed stability/downforce/cooling.
Don't know about the Honda.If it's like the R-spec,then it would also be about stability,at the expense of drag.
There aren't any 'clean' fast cars.They have coefficients of drags similar to a RAM 1500 pickup.
Old 01-22-2019, 05:20 PM   #10 (permalink)
EcoModding flying lizard
Daschicken's Avatar
Cibbie - '88 Honda CBR 250R
Motorcycle
90 day: 48.49 mpg (US)
Rarity - '06 Honda Accord EX V6
90 day: 29.88 mpg (US)
Baby viff - '86 Honda VFR 400R
Motorcycle
90 day: 42.15 mpg (US)
Latios - '08 Suzuki SV650SF
Motorcycle
90 day: 64.56 mpg (US)
Mazda 3 - '14 Mazda 3 i Sport
90 day: 43.25 mpg (US)
How about the original acura NSX? Cd of 0.32. Not amazing or anything, but not bad either.
-Kaze o tatakaimasen-
Best trip in V6: 52.0
Best tank in V6: 46.0
Best tank in Mazda: 49.9
Best tank in CBR: 61.3
Best tank in SV: 83.9
You can lead a fashion-conscious horse to unusual-looking water...
The Following User Says Thank You to Daschicken For This Useful Post:
