Old 02-24-2012, 12:48 PM   #21 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Calculated AVG speed 85 km/h or 53 MPH and at full throttle about 90%. You just need to start doing that at young age...
Front camera position is much queter because its in the center pressure point .
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
Old 03-03-2012, 10:47 AM   #22 (permalink)
Eph's 08 NAH - '08 Nissan Altima Hybrid tech package
90 day: 46.13 mpg (US)
I just noticed that TireRack did another LRR tire test in Aug., 2011:
Eco-Focused All-Season Tires: Do They Deliver on the Promise?
Wish they had done a coasting to stop distance test...
Also wish they had included the Kumho ecowings.
Anyone have any new preferences for LRRs?
Thanks,
Eph
The Following User Says Thank You to cephraim For This Useful Post:
California98Civic (03-03-2012)
Old 03-03-2012, 10:56 AM   #23 (permalink)
I just communicated with TireRack about the latest study and received the following response:
"Hey Craig,
I will pass this along. I know with the increase in LRR tires and the emphasis on miles being one of the many qualities that are being looked into, our testing should start to figure out ways have a more dynamic set of results. I am only in sales, and thus whileI test the tires like all the other salesman, I do not have any say in how or what is tested. I will, however, pass this along to those who do make those decisions. Before I do so, is there anything you would like to add as an important factor in you or others who are interested in these kinds of results? In fact, if you would like to layout an email for me with any and all concerns that you would like to see, I will be happy to pass it on for you!
Thanks!
Spencer
If you order online, please reference "Spencer" on the order as a previous contact. Thank you.
Spencer Diaz | Sales Specialist
__________________________________________________ ________
Tire Rack
7101 Vorden Parkway
South Bend, IN 46628
O: 888 428 8355 ext. 690
O: 574 287 2345 ext. 690
F: 574 236 7707
spencer@tirerack.com"
Anybody care to craft a memo I/we can share for their next test?
Old 03-05-2012, 12:09 PM   #24 (permalink)
Is anybody interested in influencing TireRack's next LRR tire study?
Old 03-05-2012, 12:36 PM   #25 (permalink)
A Legend in his Own Mind
Ken Fry's Avatar
Fun
Originally Posted by Vekke View Post
Is this looking like enough grip?
Looks like fun.
Have you been to the Saab museum near Helsinki? The guy who runs it (ran it?... this was several decades ago) gave me and a friend a ride in his Saab aero turbo (maybe 99 or 900) on gravel roads. I was not unaccustomed to going fast, having done a fair amount of motorcycle racing (mostly on pavement, but occasionally on dirt tracks)... but he definitely had my heart racing.
Your video brought back fun memories.
Old 03-05-2012, 01:23 PM   #26 (permalink)
Ken Fry's Avatar
Thanks, Craig, for putting this out there. I'd like to see real rolling resistance testing on a test rig. There are too many variables involved in real world tests to be able to conclude anything from mpg road testing -- Tire Rack's results are all within the margin of error for the test method, so really have no meaning. Even on very high quality dynos, like those used for the EPA MPG figures, with accurate adjustments for for temperature and baro pressure, no wind at all, consistent test fuel, etc etc, 2% is too small a MPG difference to be measured accurately. (I've built and operated somewhat less sophisticated dynos, which I consider fairly accurate, but I had the owner of an EPA-certified facility tell me that =/- 5% is about as close as he can get with just one test.)
On the other hand, the large differences in rr can be measured on test rigs to fairly tight limits. Low rr tires range from .006 to .010 (.010 being average rr) so drag readings, with a 1000 lb load, go from 6 lb to 10 lb: figures that can be measured to within .1 lb pretty reliably.
A test rig does not necessarily provide an actual rr as would be seen on a given road, because some use a large wheel on which the the tire rolls, whereas roads are comparatively flat. Also different road surfaces produce different rr figures, and in the same way the test rig "road" surface produces a figure that relates to that surface alone. So to be comparable, the rr figures must come from the same test machine. You could not compare Bridgestone's published .006 for the 381 with a number from a different test machine.
I think Tire Rack has gone a great job -- better than any other vendor that comes to mind, but real rr numbers would further set them apart from the competition.
I am not convinced that manufacturer rr numbers are comparable from one manufacturer to the next (and for the most part, it is hard to find manufacturer's numbers). (In fact, as I think about it, why not have the rr figure as determined by standardized equipment, right on the sidewall of every tire, alongside the tread wear and traction data?)
I think the test data from the California study was all obtained from the same test equipment (I'd have to recheck) so if that info were updated every year, then Tire Rack could publish that data, perhaps instead of their MPG data.
The Tire Rack method could be interesting if they did one extensive test with a confirmed .010 tire set and a .006 tire set on the same car, in ABABAB fashion, to illustrate the results that are obtained from this increment in rr.
Getting slighly more complicated, they could redo these test for a light and boxy car (for which aero drag predominates more of the time) and a heavy and streamlined car (for which rolling drag predominates more of the time).
Old 03-05-2012, 02:06 PM   #27 (permalink)
Ken,
I have forwarded your info on.
I'll post back when/if I hear from TireRack again.
Eph
Old 03-06-2012, 11:03 AM   #28 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Getting real independently measured RR numbers would be nice.
Fixed-speed (say 30 and 60mph) MPG tests on a track would be nice as well.
MPG tests on the road : forget them, they're not worth the effort due to too much variation, even if they always take the same circuit.
Old 03-06-2012, 11:26 AM   #29 (permalink)
FWIW, here is the response I got from TR:
"Hello!
I did receive it and sent it foreword like I had promised to do so. I do not know if this is something that I will be able to give some kind of instant answer to or not. They process these things and it definitely takes time. Especially changing anything with the testing process. Just a heads up!
Thanks"
Old 03-14-2012, 12:53 AM   #30 (permalink)
F8L
F8L's Avatar
F8L's 2012 Prius - '12 Toyota Prius Three with Solar Roof
90 day: 62.14 mpg (US)
I've traded emails with Woody at TireRack regarding their LRR tire testing but I never offered specific testing procedure ideas. I really hope they stop using their test BMWs for the gas mileage testing though. lol
I keep a current list of LRR tires available in Prius sizes over at Priuschat.com. Because everyone has specific needs in a tire it is hard to saw which is best because not everyone has the same needs.
Here is a quick summary of the Prius favorites:
Priuschat.com Favorites
Michelin Energy Saver A/S
Michelin Primacy MXM4 (V-rated)
Bridgestone Ecopia EP100 and EP422
Continental ContiProContact with EcoPlus
Yokohama dB Super E-Spec
Goodyear Assurance Fuel Max
Hankook Optimo H727 (not LRR but a good tire)
For those who just want to be told what to get here it is:
Michelin Energy Saver A/S = Best mpg, good wear but lacking in performance.
Goodyear Assurance Fuel Max = Great mpg but behind the others in road noise, handling, and overall road manners and performance. Great tread wear but lacking wet traction.
Bridgestone Ecopia EP100 = Awesome mpg! Good wet traction and handling tire but lacking in dry braking and traction. Tread wear average.
Yokohama dB Super E-Spec = Great mpg (better than Fuel Max). Great handling, dry braking. Sort of a performance tire that gets excellent mpg but low to good tread wear and no warranty.
Continental ContiProContact with EcoPlus = Least mpg of those listed above (just beihnd Fuel Max by a few 10ths) but what it loses in mpg it makes up for with excellent handling and wet traction, very high tread wear warranty, low price, and low noise.
I've owned the Yokohama dB Super E-Spec, Goodyear Integrity, Nokian i3, Michelin Primacy MXM4 and I will be installing the brand new Yokohama AVID Ascend.
2012 Prius Three with Solar Roof - Blizzard Pearl w/dark gray interior: Prius Plug-In 15" Wheels | Michelin Energy Saver A/S 195/65/15 tires | TRD Lowering Springs | WeatherTech FloorLiners | Scangauge II | Morimoto/DDM HIDs 5000K | Clazzio Leather Seat Covers | Best Tank: 71.7mpg@702miles | Best Trip: 95.9mpg@233miles
