Old 07-08-2015, 09:01 PM   #11 (permalink)
Originally Posted by California98Civic View Post
Remembering to refill a water bottle with (I assume) highly purified water would be viewed by most consumers as a bigger pain than high octane fuel. And the cost savings in fuel would be at least partly offset by the cost of such water, wouldn't it? Why is BMW interested?
You might mean distilled water. Some alcohol might be added to lower the freezing point too.
Old 07-08-2015, 11:26 PM   #12 (permalink)
If you read the article...
In the 1 Series prototype, water is recovered from the air conditioning system--a much more convenient method.
The Following 2 Users Say Thank You to Daox For This Useful Post:
California98Civic (07-09-2015), Xist (07-10-2015)
Old 07-09-2015, 12:59 AM   #13 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Aha! Yes, I missed that line... reading a little too quickly. But I wonder still how they plan the car to respond to drivers in dry or cool climates... or if they stamp on the go pedal a lot but hate AC. Winter? I guess the ECU could run things differently if there is no water to inject? Or there could be a way to add water.
Anyway, it's pretty damned clever, even if it seems to me to be something for a niche more than the mass market. I guess that's their goal.
Last edited by California98Civic; 07-09-2015 at 11:55 AM.. Reason: "there" not "their"
Old 07-09-2015, 08:37 AM   #14 (permalink)
I'd imagine they'd have a 'low water' light. If you run out of water, they'd really have to retard timing I would think to avoid knock.
I honestly can't see the A/C system providing that much water, but I could be wrong. Also, that fuel efficiency increase is really going to take a hard hit if you have to use the A/C to refill the water supply.
The Following User Says Thank You to Daox For This Useful Post:
Xist (07-10-2015)
Old 07-09-2015, 08:43 AM   #15 (permalink)
Focus - '05 Ford Focus tdci Futura
Or they use the water from the a/c to get better fe and make up for the loss from the a/c?
Old 07-09-2015, 09:26 AM   #16 (permalink)
Miser in training
robbcoll's Avatar
The Hedgehog - '14 Chevy Sonic LT
90 day: 43.03 mpg (US)
I would be worried about hydro-locking the engine.
Old 07-09-2015, 09:57 AM   #17 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
I'm sure climate control is always on when one drives a BMW. AC is used even in the winter to keep the windows from fogging. Just call it a de-humidifier.
I'm not coasting, I'm shifting slowly.
Old 07-09-2015, 12:06 PM   #18 (permalink)
Cyborg ECU
I'd bet the ECU is set to prevent water injection in a number of scenarios long before there is significant risk of hydro-lock, much in the way Honda's lean burn system will not work if there is the CEL is on.
Yes, and even if the A/C is always-on, in an arid or semi-arid climate, like where I live, there will be less water to remove and therefore to inject. I would think they would want to offer an ability to add water somehow, like one might add windshield fluid. In fact, to reduce the likelihood somebody jus dumps tap water into the system, they could call it "BMW-Power-Water" and charge oodles of dollars for it. "Use only BMW 345p Special Water" could be printed on the cap... dealerships will love that.
The Following 2 Users Say Thank You to California98Civic For This Useful Post:
AbramWagner (07-09-2015), UFO (07-09-2015)
Old 07-09-2015, 12:11 PM   #19 (permalink)
UFO
UFO's Avatar
Love it, "BMW-Power-Water"
Old 07-09-2015, 02:39 PM   #20 (permalink)
If the natural humidity is low just leave a bucket with tap water inside, far cheaper than buying distilled water.
Retard ignition timing, increase the intake valve timing to lower the dynamic compression ratio (a VVT miracle), sure they know how to overcome it.
What if it had an all-electric A/C, like the Prius?
